So for my project I use STM32L4R5 (custom PCB) and need to connect parallel 8 wires to control addresses in a sensor. I am toggling 8 GPIO pins in parallel providing the addresses, but speed is crazy low (I would need 10~20MHz). I checked several other similar problems in different sites and optimized as much as I can. I guess it may be very simple error but what I have at the moment is as follows:
basically, I have 48MHz crystal, I use PLL to go up to 100MHz for system clock, 80MHz for ADC (different topic...). I actually touched the code a few times testing between 48MHz and less so I paste also the final clock settings in code:
void SystemClock_Config(void)
RCC_OscInitTypeDef RCC_OscInitStruct = {0};
RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
RCC_PeriphCLKInitTypeDef PeriphClkInit = {0};
if (HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE1) != HAL_OK)
Error_Handler();
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI48|RCC_OSCILLATORTYPE_HSE;
RCC_OscInitStruct.HSEState = RCC_HSE_ON;
RCC_OscInitStruct.HSI48State = RCC_HSI48_ON;
RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
RCC_OscInitStruct.PLL.PLLM = 12;
RCC_OscInitStruct.PLL.PLLN = 50;
RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
RCC_OscInitStruct.PLL.PLLQ = RCC_PLLQ_DIV2;
RCC_OscInitStruct.PLL.PLLR = RCC_PLLR_DIV2;
if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
Error_Handler();
RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
|RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;//RCC_SYSCLKSOURCE_HSE;//RCC_SYSCLKSOURCE_PLLCLK;
RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;//RCC_SYSCLK_DIV1;
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;//RCC_HCLK_DIV4;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_4) != HAL_OK)
Error_Handler();
if(vers==1){
PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_I2C1|RCC_PERIPHCLK_USB
|RCC_PERIPHCLK_ADC;
PeriphClkInit.I2c1ClockSelection = RCC_I2C1CLKSOURCE_PCLK1;
PeriphClkInit.AdcClockSelection = RCC_ADCCLKSOURCE_PLLSAI1;//RCC_ADCCLKSOURCE_SYSCLK
PeriphClkInit.UsbClockSelection = RCC_USBCLKSOURCE_HSI48;
PeriphClkInit.PLLSAI1.PLLSAI1Source = RCC_PLLSOURCE_HSE;
PeriphClkInit.PLLSAI1.PLLSAI1M = 6;
PeriphClkInit.PLLSAI1.PLLSAI1N = 20;
PeriphClkInit.PLLSAI1.PLLSAI1P = RCC_PLLP_DIV2;
PeriphClkInit.PLLSAI1.PLLSAI1Q = RCC_PLLQ_DIV2;
PeriphClkInit.PLLSAI1.PLLSAI1R = RCC_PLLR_DIV2;
PeriphClkInit.PLLSAI1.PLLSAI1ClockOut = RCC_PLLSAI1_ADC1CLK;
if(vers==2){
PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_I2C1|RCC_PERIPHCLK_ADC;
PeriphClkInit.I2c1ClockSelection = RCC_I2C1CLKSOURCE_SYSCLK;//RCC_I2C1CLKSOURCE_PCLK1;
PeriphClkInit.AdcClockSelection = RCC_ADCCLKSOURCE_PLLSAI1;//RCC_ADCCLKSOURCE_PLLSAI1;//RCC_ADCCLKSOURCE_SYSCLK
if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
Error_Handler();
//__HAL_FLASH_SET_LATENCY(FLASH_LATENCY_4);
__HAL_FLASH_PREFETCH_BUFFER_ENABLE();
__HAL_FLASH_DATA_CACHE_ENABLE();
I added 4 Flash wait states according to the reference manual.
Now we reach the funny part. My original code was change into the BSRR register (commented in the loop). I noticed this line takes about 30 tics to execute. So I made an array "lineindex" with all 32bit values to be written in BSRR, no calculations required;
Oscilloscope on the lowest pin gave me this:
I was surprised by the low value. Run from flash/RAM brought like 100-200kHz difference. So spent 2 days studying how to do the same using DMA. Now I use TIM1 to trigger DMA to make MEM2PERIPH transfer (MEM source is the 32bit word array, sending data through DMA directly to BSRR). If I get it right MCU is not used during the burst sends (160transfers at once), manual says bus can run on 120MHz (set at 100MHz now), so... what happens? Code:
//Timer
static void MX_TIM1_Init(void)
/* 3 (Timer TIM1) */
__HAL_RCC_TIM1_CLK_ENABLE();
htim1.Instance = TIM1;
htim1.Init.Prescaler = 0;
htim1.Init.CounterMode = TIM_COUNTERMODE_UP;
htim1.Init.Period = 7;
htim1.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
htim1.Init.RepetitionCounter = 0;
HAL_TIM_Base_Init(&htim1);
/* 7 (Enable TIM for DMA events) */
__HAL_TIM_ENABLE_DMA(&htim1, TIM_DMA_UPDATE);
TIM_ClockConfigTypeDef sClockSourceConfig = {0};
sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL;
if (HAL_TIM_ConfigClockSource(&htim1, &sClockSourceConfig) != HAL_OK)
Error_Handler();
// DMA2 (includes ADC code on channel3, channel6 is used for the current loop)
static void MX_DMA_Init(void)
/* DMA controller clock enable */
__HAL_RCC_DMAMUX1_CLK_ENABLE();
__HAL_RCC_DMA2_CLK_ENABLE();
__DMA2_CLK_ENABLE();
/* DMA interrupt init */
hdma_adc1.Instance = DMA2_Channel3;
hdma_adc1.Init.Direction = DMA_PERIPH_TO_MEMORY;
hdma_adc1.Init.PeriphInc = DMA_PINC_DISABLE;
hdma_adc1.Init.MemInc = DMA_MINC_ENABLE;
hdma_adc1.Init.PeriphDataAlignment = DMA_PDATAALIGN_HALFWORD;
hdma_adc1.Init.MemDataAlignment = DMA_MDATAALIGN_HALFWORD;
hdma_adc1.Init.Mode = DMA_CIRCULAR;
hdma_adc1.Init.Priority = DMA_PRIORITY_HIGH;
//HAL_DMA_DeInit(&hdma_adc1);
HAL_DMA_Init(&hdma_adc1);
__HAL_LINKDMA(&hadc1, DMA_Handle, hdma_adc1);
DMAMUX1_Channel9->CCR &= ~( DMAMUX_CxCR_DMAREQ_ID );
DMAMUX1_Channel9->CCR = 0x5;
/* 4 (DMA2 Channel6) */
hdma_tim1_uev.Instance = DMA2_Channel6;
hdma_tim1_uev.Init.Direction = DMA_MEMORY_TO_PERIPH;
hdma_tim1_uev.Init.PeriphInc = DMA_PINC_DISABLE;
hdma_tim1_uev.Init.MemInc = DMA_MINC_ENABLE;
hdma_tim1_uev.Init.PeriphDataAlignment = DMA_PDATAALIGN_WORD; // 16 bits
hdma_tim1_uev.Init.MemDataAlignment = DMA_MDATAALIGN_WORD;
hdma_tim1_uev.Init.Mode = DMA_NORMAL;
hdma_tim1_uev.Init.Priority = DMA_PRIORITY_LOW;
HAL_DMA_Init(&hdma_tim1_uev);
__HAL_LINKDMA(&htim1,hdma[TIM_DMA_ID_UPDATE],hdma_tim1_uev);
DMAMUX1_Channel12->CCR &= ~( DMAMUX_CxCR_DMAREQ_ID );
DMAMUX1_Channel12->CCR = 46U;
//DMAMUX1_Channel9->CCR &= ~( DMAMUX_CxCR_DMAREQ_ID );
//DMAMUX1_Channel9->CCR |= ( 0x8 << DMAMUX_CxCR_DMAREQ_ID_Pos );
/* DMA1_Channel1_IRQn interrupt configuration */
HAL_NVIC_SetPriority(DMA2_Channel3_IRQn, 0, 0);
HAL_NVIC_EnableIRQ(DMA2_Channel3_IRQn);
HAL_NVIC_SetPriority(DMA2_Channel6_IRQn, 0, 0);
HAL_NVIC_EnableIRQ(DMA2_Channel6_IRQn);
/* DMAMUX1_OVR_IRQn interrupt configuration */
HAL_NVIC_SetPriority(DMAMUX1_OVR_IRQn, 0, 0);
HAL_NVIC_EnableIRQ(DMAMUX1_OVR_IRQn);
// Loop in main
for (counteri=1;counteri<100000;counteri++){
HAL_DMA_Start_IT(htim1.hdma[TIM_DMA_ID_UPDATE],(uint32_t) lineindex,(uint32_t)&GPIOF->BSRR, 160);
__HAL_TIM_ENABLE(&htim1);
while((TIM1->CR1 & 1U));
I know the timer Period is a magic number. Changed timer speed from like 5MHz to 50MHz. The shown magic number leads to the maximum loop speed of 6MHz I got, so just left it there.
Now the questions. What am I doing wrong? In other posts I saw reasonable speeds of 15-20MHz with pin toggle function. Direct writing in the registers and even excluding the MCU did not help. I guess it is either some clock error I don't see, or just bus waiting, but it looks strange since there is nothing else going there at the moment. I noticed that in debug mode one asm("NOP"); takes 4 tics. No change regardless whether I run from Flash or RAM (thought it is wait states at first). On slower clock I couldn't even reach 1MHz. Also, big worry is the transient peaks. -0.7~-0.8V to 4V? I wonder whether this is some oscilloscope settings issue or it is normal?
To add more, the code bellow is used since I read analog data from the sensor:
for(uint8_t vc = 1; vc < 321; vc++){
GPIOF -> BSRR = lineindex[vc-1];//(vc) | (((~vc) & 0xFF) << (16)); //col
asm("NOP");
ADC1->CR =268435461U;//|= 4U; // start ADC reading
while(!(ADC1->ISR & ADC_ISR_EOS)); // wait for ADC conversion to complete
ADC1->ISR &= 14U;
More magic numbers, but tried to eliminate all possible calculations even when values are written in registers. So, with ADC, reading 4 channels using DMA, at 80MHz, 2.5cycles sampling, 12bit, I got less than 500kHz. ADC should be 5.88Msps, 4 channels with some overhead, I would expect at least double, but please if you have any ideas correct me:
// Loop in main ... for (counteri=1;counteri<100000;counteri++){ ...
it looks like you're waiting for the timer withwhile((TIM1->CR1 & 1U));
. But surely you should be waiting for the DMA to complete rather than the timer? Each timer event will trigger a single DMA transfer, so as you have it now it seems to me that you only get a single DMA transfer before restarting it over again. \$\endgroup\$
