I'm working on an electronics project that was using an Arduino to drive a 5V relay module specified here.
The relay switches a 240V AC (upto) 10A load.
I have now moved to using an ESP32 which uses 3.3V control pins and have some questions about finding a replacement that I would like to eventually incorporate into a custom PCB-
- Does a suitable relay exist for this load than can be actuated by 3.3V?
- If not what is the most appropriate way to boost the 3.3v signal to 5V?
- What's the purpose of the optoisolator in the above design? Should this be included in a circuit to replace the relay module?
- Are there any other important components on the relay module I need to include in my circuit?
