This is the always block of the RTL having nested case statements inside:
always@(posedge clk)
    begin
        state<=in;
        //index<=3'b000;
    if(rst)
        begin
            state<=3'bxxx;
            out<=3'bxxx;
        end
    else
        case(state)
                   s0:  begin
                            addr<=0;
                            index<=3'b000;
                        case(index)
                              3'b000:begin
                                    if(ram && !visited[0])
                                    begin
                                       state<=s0;
                                       pstate[count]<=s0;
                                       count<=count+1;
                                    end
                                else
                                begin
                                    index<=index+1;
                                    addr<=index+1;
                                end
                                end
And this is my testbench:
module DFS_tb();
    reg [2:0] in;
    reg rst;
    reg clk;
    wire [2:0] state;
    wire [2:0] out;
    wire [5:0] visited;
    wire [2:0] index;
    DFS uut(in,rst,clk,visited,state,index,out);
    initial clk=1'b0;
    initial
    begin
        rst=1;
        #10 rst=0;
        #15 in=0;
    end
    always #5 clk=~clk;
    endmodule
The waveforms are obtained as below.
I expect the index to change at 25ns, but it is getting updated with 1 cycle delay (i.e. 35ns.) I would like to know the reason for this.
Why 1-cycle delay?
    \$\begingroup\$ Incomplete code + improper reset logic. You should revisit your fundamentals. \$\endgroup\$
    – Mitu Raj
    Aug 19 '21 at 21:57
You don't seem to be showing us all of your Verilog code...that makes it tough to help you. However, I see that you have the clk and in signals changing at the same time, which can cause unpredictable behavior. Change the transitions of your inputs to be 2 or 3 nanoseconds before the rising clock edge.
Using in and out as signal names is a very bad idea, since these are keywords in Verilog.
