I am working with ATtiny85. I want to put my MCU in IDLE Sleep mode and after every five minutes, I want to write data into EEPROM. I am using Timer 0 overflow interrupt to count 5 mins. Counting will be done in ISR. I have a query here
  1. Does CPU come out of IDLE Sleep mode when timmer overflow interrupt is generated? In the datasheet, they didn't give Timmer Overflow interrupt as a wake-up source.
void setup() {
  mySerial.begin(9600);
  set_eeprom_default(); // Initialize the EEPROM with default values
  configure_idle_mode(); // Configure idle sleep mode bits
  configure_interrupt_wakeup();
  timer_setup(); // Initialize timer and start timer
  EEPROM.get(Address, timer_count); // Get the value of timer counter
void loop() {
  if (timer_count < max_timer_count) {
    enable_sleep(); // Enable Sleep mode. MCU goes to sleep here
  if (is_five_min == 1) { // Update EEPROM value after every 5 min
    update_eeprom();
    is_five_min = 0; // Reset the flag
  • 4
    \$\begingroup\$ are you using an attiny85 or esp32? \$\endgroup\$
    – dandavis
    Aug 21, 2021 at 4:45
  • \$\begingroup\$ I am using ATtiny85 \$\endgroup\$
    – sri
    Aug 23, 2021 at 5:20
Yes, TIMER0 overflow is a wakeup from sleep. Relevant text in Section 7.1.1: "Idle mode enables the MCU to wake up from external triggered interrupts as well as internal ones like the Timer Overflow". Also see Table 9-1 (Reset and Interrupt Vectors). It sounds like you've already declared the TMR0_OVF_vect ISR.
Additionally, enable_sleep does not put the AVR into the sleep mode, it only sets the SE bit in the MCUCR register. You have to call sleep_cpu() afterwards to actually put the microcontroller to sleep. Typically, the sequence would be:
sleep_enable();  // Set SE bit
sei();           // Enable interrupts
sleep_cpu();     // Go to sleep
sleep_disable(); // Clear SE bit
See the description of this in the avr-libc documentation.
  • \$\begingroup\$ Thank you awjlogan \$\endgroup\$
    – sri
    Aug 23, 2021 at 5:21
