Why does a GDDR5 memory which is designed to work at 1250MHz gets slow at 1450MHz? Because of ECC check start? Because it is not supposed to work at that frequency(hard-coded?)? Because of some quantum physics related resonance condition? Maybe capacitors get short-circuiting at higher frequencies or coils get more inductant?
Note : it gets faster after 1575 MHz and has a peak at 1650MHz. The slower peak is at 1375 MHz.
Side note : applied many voltages through 1.5V...1.7V but failed to change mem-behaviour(1.5V is standard)
Deep-note : i also have coil-whining when not overclocked. Overclocking gets me rid of coid whining sound.
This is for HD7870 graphics card.
Thanks.
closed as off topic by Kortuk Feb 17 '13 at 17:15
Questions on Electrical Engineering Stack Exchange are expected to relate to electronics design within the scope defined by the community. Consider editing the question or leaving comments for improvement if you believe the question can be reworded to fit within the scope. Read more about reopening questions here. If this question can be reworded to fit the rules in the help center, please edit the question.
  • \$\begingroup\$ This is the type of question you should ask on Super User. Edit and improve your questions there to remove your Q ban. \$\endgroup\$ – Kortuk Feb 17 '13 at 17:15
One way this sort of peak/valley behaviour can happen with DRAM performance: there are several inter-related speed parameters that have to be satisfied.
One is the simple bus speed that you are adjusting : as you increase it, data transfer to/from DRAM gets faster.
Another is the internal access time between the 2-D memory array and a buffer that holds a single row of values (Row Access Time). Usually after fetching a row, we do a lot of accesses in that row (adjacent pixels share the row) so this has relatively little effect.
Another is the delay between asking for a particular value from that row (i.e. at a particular column address) and that value being available on the output pins (Column Access Time).
Now the problem comes because the Column Access time we need is a fixed value (say 20ns) but the bus speed is variable. But the internals can't usually work in fractions of a clock cycle, so Column Access time is actually expressed as a whole number of bus cycles; the datasheet may call this CAS Latency or CL.
Now if CL = 7 cycles at 1375 MHz but you then increase the bus speed a little, CL has to increase to 8 cycles to meet the Column Access time, so memory accesses slow down, and actual performance drops. Increase bus speed and performance increases again, until eventually 8 bus cycles is too short for Column Access time, and CL has to be increased to 9 cycles.
These are not exact numbers; you would have to find those from the datasheets on the memory fitted to your graphics card.
EDIT : playing with a spreadsheet :
You observed highest performance at 1375 MHz and 1650 MHz.
These frequencies happened to be 275 MHz apart.
Coincidentally (not!) they happen to be 5 * 275 MHz and 6 * 275 MHz. Therefore your observations are consistent with a column access time of 1/275MHz, and CL=5 for frequencies up to 1375 MHz, and CL=6 between 1376 and 1650 MHz.
You can probably find a similar performance peak (and cooler running chips!) at 1100 MHz and CL=4.
  • \$\begingroup\$ Nice answer. This is hynix i think, will look at datasheet of t2c version. Thanks. \$\endgroup\$ – huseyin tugrul buyukisik Feb 17 '13 at 19:27
  • \$\begingroup\$ If you don't have any luck there, micron.com datasheets are excellent and they probably make an equivalent part. It's probably useful to add a comment if you confirm (or otherwise) the details. \$\endgroup\$ – Brian Drummond Feb 17 '13 at 20:02
