I would like to obtain an absolute value of input signal with TL072 or MC4558 op amps (or other amp) with single supply.
When I connect the circuit upper one follows the signal and adds noise and lower one has constant value on output. Input signal is <-9,+9> V, up to 20 kHz (guitar).
I use R = 10 kΩ, C = 1 nF.
What do I miss? Should I use another op amp? Or did I omit something from documentation? Maybe there are better circuits?
Edit: Should I put input signal through transistor to get high resistance?
I will be grateful for any help or information.
