I'm trying to identify/match this 2-pin connector, would anyone happen to know what type it is / who makes it?
Thank you so much for your help!
It is 03062023 from Molex Wire to Wire "Standard .062"+ and Standard .062" Pin and Socket Connector Systems" connector
  • \$\begingroup\$ So definitely too small, pitch is only 3.68 (mine's 6), but at least I have a lead on the type/manufacturer, thank you so much! \$\endgroup\$ Aug 23, 2021 at 4:05
  • \$\begingroup\$ Pretty sure I found it, 03092022, has a 6.3mm pitch, so that looks right. Thanks again! \$\endgroup\$ Aug 23, 2021 at 4:30
    \$\begingroup\$ Thanks @MyFingerHertz \$\endgroup\$
    – jay
    Aug 23, 2021 at 13:32
