When I use the Y-modem protocol on stm32 board, I’m faced with data count bytes. There are two bytes on the frame, one byte is data count another is 0xFF-dataCount.
SOH 01 FE data[] 1A...1A CRCH CRCL
But I have a question on the this process; When I send 128 byte every process, than 8 byte data get max "255" = 0xFF value, So If I try to transmit 256+ data, I will face with problem because the data count value have one byte.
Why the data count 1 byte on the Y modem frames? If we use the 255+ data count frame what can I do?
  • \$\begingroup\$ You can either send 128 byte packets starting with SOH, or 1024 byte packets starting with STX. \$\endgroup\$
    – Codo
    Aug 23, 2021 at 6:55
  • \$\begingroup\$ @gogogo There is no block size sent in Ymodem packet. Or açtually the first byte defines the packet size. What you are asking about is a block count number, a running counter which increases for each block. \$\endgroup\$
    – Justme
    Aug 23, 2021 at 7:11
  • \$\begingroup\$ block count sorry \$\endgroup\$
    – gogogo
    Aug 23, 2021 at 7:13
  • \$\begingroup\$ So, If the block count byte equals = 00 and data include 1024 byte, Could we say the data count more than 255+ ? \$\endgroup\$
    – gogogo
    Aug 23, 2021 at 7:43
The block count increases by one each packet and it simply overflows and wraps around from 255 to 0. It reads in the YMODEM documentation.
