I'm designing schematics with the audio codec CS42448. The datasheet suggests output filters and I chose to follow the passive filter recommendation. I'm not sure though how to follow the calculation for the capacitor (C). Can I choose any value for the resistor (R ext)? And the Fs capacitor, does it refer to the 3.3uF (0.0000033)?
No, the Fs is the cutoff frequency you want for the filter. Rext is the load resistance of the device where the audio is being output. C is the capacitor for the lowpass filter.
See the evaluation board schematics for example values for the passive filter.
  • \$F_S\$ is the sampling frequency. You want to remove it.
  • \$R_{ext}\$ represents the impedance of the load you expect.
\$R_{ext}\$ and the 560 ohm resistor are effectively in parallel to each other. If \$R_{ext}\$ is much larger than 560 ohms, then it matters very little. If the output of the filter goes to an op-amp input, \$R_{ext}\$ will be very large - the equation reduces to \$C = \frac{1}{4 \times \pi \times F_s \times 560}\$
