I have a project that I need input on.
Is it possible to build a hybrid bank out of ultra-capacitors (UC) and batteries?
The generalized flow of the system I'm thinking is from solar (48V) to UCs (48V,) to batteries (48V,) then split simultaneously to an inverter for 120VAC and a step-down transformer for 12V.
Is it better to put the UCs before or after the batteries?
I'm purposely leaving out battery chemistries because I believe this concept is voltage agnostic. It shouldn't matter if it is lead acid, AGM, LiFePo, LTO, etc.
... from your description, there is no before or after \$\endgroup\$
