I am trying to calculate the resolution of my simple force sensor system in Newton [N].
The sensor system consists of a simple voltage divider, where the voltage across the FSR is measured by an 8-bit ADC.
I have calibrated it using a force push-pull gauge, in increments of 1 N in a range from 1-10N, noting down the ADC output, see table.
According to this link, the resolution would be calculated as follows:
Resolution = (V_ref * FS_input) / (V_fso * ADC_resolution)
Looking at the graph, ignoring the fact that my transfer function is non-linear and thus the sensitivity degrades with higher forces and thus the resolution with it, the theoretical resolution of my system assuming a linear voltage change to force input, would be:
FS_input = 10N-1N = 9N ---> because i measured from 1-10 Newtons [N]
V_fso = 2.462V - 1.702V = 0.76V ---> this is the output voltage [V] range for the input force range of 1-10 Newtons [N]
V_ref = 3.3V ---> this is the ADC reference voltage and the voltage across the whole voltage divider
ADC_resolution = 2^n = 2^8 = 256
Resolution = (3.3V * 9N) / (0.76V * 256) = 0.153 N
Meaning the smallest detectable change in force [N] with my 8-bit ADC would be 0.153N.
Is this the correct way to calculate the resolution?
Voltage divider
table
graph
Your answer is right, but the way you got there is very complicated, and I don't really follow it. From the highest measurement to the lowest measurement is 191 - 132 = 59 counts, and that covers a range of
10 - 1 = 9 Newtons, so the average resolution over that range is 9 / 59 ~ 0.153 N / count.
The curve-fit you did also looks fine, though again, going via voltage instead of directly relating force to ADC count only serves to complicate things.
  • \$\begingroup\$ The transfer function is very non-linear so it's better not to take the average. Divide the steps in the force column (all 1s) by the steps in the count column. This gives a resolution of 0.07 N between 1 and 2 N vs. a resolution of 0.5 N between 9 and 10 N. \$\endgroup\$
    – DamienD
    Sep 4, 2021 at 7:02
  • \$\begingroup\$ @DamienD I entirely agree. In fact I had that in my answer, but I decided to eliminate clutter. \$\endgroup\$
    – hobbs
    Sep 4, 2021 at 8:06
  • \$\begingroup\$ IMHO it's not clutter and would improve your answer a lot -- there's a factor of seven difference between the ends of the scale. \$\endgroup\$
    – DamienD
    Sep 4, 2021 at 8:49
