Are pull-up/down resistors (whether internal or external) only needed for MCU INPUT pins? In contrast, an MCU pin configured as an OUTPUT "knows what level it's at" because it does the driving - a "floating" MCU OUTPUT pin tied to some input of another circuit doesn't make sense, because the state of the MCU pin can only be high or low... do I have this right? Now, upon MCU bootup or failure, it may be beneficial to have a pull-up/down tied to this "MCU output to IC input" line to ensure that the input to some IC is never floating.
Maybe I just answered my own question here... pull-up/down resistors can be used on both input and output pins, depending on application?
