I need to isolate the antenna from the WiFi transmitter. There are some solutions on the market but none suitable for my application.
So I have started some experiments.
Which effectively creates 9 capacitors (three on the signal line six on the shield. The shield ones are parallel connected in pairs)
But I would like to use stock capacitors instead. The second board has 3 1pF capacitors in series on both sides (values on schematic are not correct)
But this version efficiently is a short circuit for this frequency signal.
When I reduce the number of capacitors to one it is much better.
Two capacitors behave much worse.
The length of the boars is 1/4 of the wave length in the copper.
The question. Why is the three (or two) capacitor version is almost blocking the signal?
