Looking at the reference design for an Intel CPU (VCCA_CLKLDO_1P8 is a an analog supply to the PCH Clock), I didn't understand why there is an inductor between VCCA_CLKLDO_1P8_R and +VCCA_CLKLDO_1P8.
VCCA_CLKLDO_1P8_R is the source voltage and it comes from the digital power supply and VCCA_CLKLDO_1P8 is the plane to which the CPU pin is connected. Also, what is the use of the RC circuit and why were these values chosen?
Enter image description here
The inductor and capacitor form an LC filter to filter out the switching noise either from the power supply itself or from the other components connected to the power supply. The resistor dampens the LC filter to prevent unwanted resonance. LC filters like this often use a high ESR tantalum capacitor instead of adding a separate resistor.
  • \$\begingroup\$ Aren't tantalum capacitors a fire hazard? \$\endgroup\$ Sep 11, 2021 at 23:54
  • \$\begingroup\$ @Peter absolutely. But they’re still pretty commonly used for this. \$\endgroup\$
    – Ryan
    Sep 12, 2021 at 4:56
Most likely only the designers know that and the info might not be public, so we have to guess.
Inductor and capacitor is used as a LC filter. The filter removes noise and ripple that might come from the power supply or the chip digital supply pins, so that the voltage that powers the sensitive analog power supply for the clock has less noise and ripple so it can generate cleaner clock.
The capacitor and inductor values are designed to result into suitable low pass cut-off frequency so DC is passed and high frequency AC that might start to affect the cleanliness of the clock is filtered away. As the inductor increases the power supply impedance, the capacitor must be large enough to bring the impedance down to a suitable level so the ripply currents taken by the filtered node do not result into too high ripply voltage at the capacitor.
And since LC filters exhibit resonance and ringing if not properly damped, the resistor might be added to introduce just enough losses to damp resonances and ringing enough to not be a problem.
