I'm quite new to electrical engineering, so if I didn't post something that may help to solve my problem, ask for it in comments.
I wanted to connect a Raspberry Pi 4B with a board with an STM32F779 on it.
I connected them via USB virtual COM port.
I wrote a program for the Raspberry Pi using Java and Pi4J library.
They are connected and can exchange info with each other, but when I send a byte array from the Raspberry Pi with a zero byte in it every byte after this byte also becomes zero.
Java code:
package MainPRJ;
import com.pi4j.io.serial.*;
import java.io.IOException;
public class COMToCheck
    private static byte[] comTxData = new byte[48];
    public static void StartCOM()
        Thread comThread = new Thread(() ->
            // create an instance of the serial communications class
            final Serial serial = SerialFactory.createInstance();
            // create and register the serial data listener
            serial.addListener(new SerialDataEventListener()
                @Override
                public void dataReceived(SerialDataEvent event)
                    try
                        System.out.println("[HEX DATA]   " + event.getHexByteString());
                    catch (IOException e)
                        // logging
            try
                // create serial config object
                SerialConfig config = new SerialConfig();
                config.device("/dev/ttyACM0")
                        .baud(Baud._57600)
                        .dataBits(DataBits._8)
                        .parity(Parity.NONE)
                        .stopBits(StopBits._1)
                        .flowControl(FlowControl.NONE);
                // open the default serial device/port with the configuration settings
                serial.open(config);
                // continuous loop to keep the program running until the user terminates the program
                while(true)
                    try
                        // this one is OK
                        // the result on the board: 01,F3,F4,F5,F6,F7,F8,F9,FA,FB,FC,FD,FE,FF...
//                      serial.write((byte)1, (byte)243, (byte)244, (byte)245, (byte)246, (byte)247,
//                                    (byte)248, (byte)249, (byte)250, (byte)251, (byte)252, (byte)253, (byte)254, (byte)255);
                        // this one is NOT OK
                        // the result on the board: 01,F3,F4,F5,F6,00,00,00,00,00,00,00...
                        serial.write((byte)1, (byte)243, (byte)244, (byte)245, (byte)246, (byte)0,
                    catch(IllegalStateException ex)
                        // logging
                    Thread.sleep(500);
            catch(IOException | InterruptedException | IllegalArgumentException ex)
                // logging
        comThread.setDaemon(false);
        comThread.setPriority(Thread.MAX_PRIORITY);
        comThread.start();
I receive data on my board like this:
static int8_t CDC_Receive_FS(uint8_t* Buf, uint32_t *Len)
  /* USER CODE BEGIN 6 */
   USBD_CDC_SetRxBuffer(&hUsbDeviceFS, &Buf[0]);
  strncpy(usbRXData,(char*)Buf,*Len);
  usbRXData[*Len]=0;
  usbIsOK = 1;
  USBD_CDC_ReceivePacket(&hUsbDeviceFS);
  return (USBD_OK);
  /* USER CODE END 6 */
Where could I have made a mistake?
    \$\begingroup\$ I suspect this has something to do with null-terminated strings. \$\endgroup\$
    – Hearth
    Sep 12, 2021 at 15:03
  • \$\begingroup\$ Сould you tell me anything more about this? \$\endgroup\$ Sep 12, 2021 at 15:05
  • 6
    \$\begingroup\$ A string in C is terminated with a NULL which is a value of 0. So your strncpy call stops copying when it gets to the 0 value you sent. If you're trying to copy a block of bytes with a known size you should be using memcpy. \$\endgroup\$
    – brhans
    Sep 12, 2021 at 15:13
  • 5
    \$\begingroup\$ @brhans That should be an answer, I think! \$\endgroup\$
    – Hearth
    Sep 12, 2021 at 15:21
    \$\begingroup\$ @crackanddie: You can write your own answer (and accept it) since you solved the problem. \$\endgroup\$
    – JRE
    Sep 13, 2021 at 7:30
Thanks to @Hearth and @brhans for their help in the comments, but for some reason @brhans doesn't leave their answer here.
So I changed my code like this:
  memcpy(usbRXData,(char*)Buf,*Len);
  usbRXData[*Len]=0;
  usbIsOK = 1;
  return (USBD_OK);
  • \$\begingroup\$ So did this work for you now? \$\endgroup\$
    – Mitu Raj
    Sep 13, 2021 at 10:43
  • \$\begingroup\$ yes. But it was really hard to understand that the problem was right here. I even thought that it could be because of multithreading on java and so I tried to use thread locks but it didn't help. So I spent 2 days to understand that the problem should be in board firmware. \$\endgroup\$ Sep 13, 2021 at 12:05
  • \$\begingroup\$ Okay, then you can mark this answer as solution. \$\endgroup\$
    – Mitu Raj
    Sep 13, 2021 at 12:43
  • \$\begingroup\$ yes, but I can mark it only after a day after answering :) so do not worry about it \$\endgroup\$ Sep 13, 2021 at 13:22
