-1
I want to build a vactrol. That means I have to build a device that converts the incoming audio signal into brightness levels. I found this.
I tried building this:
This does not seem to work. The LED does not change its brightness.
Do you have an idea what could be the problem or do you have a better idea?
  • \$\begingroup\$ What are the characteristics of your input signal and what is providing it? \$\endgroup\$
    – vir
    Sep 13 at 22:24
  • \$\begingroup\$ What wires did you connect between your headphone output and your circuit? Did you connect shield to battery negative (ground on your schematic)? \$\endgroup\$
    – Transistor
    Sep 13 at 22:27
  • \$\begingroup\$ The audio signal comes from my computer and ranges around +0.5V and -0.5V \$\endgroup\$
    – Joh
    Sep 13 at 22:32
  • \$\begingroup\$ I wired the right and left channel together as IN in the schematic. Audio ground to battery ground \$\endgroup\$
    – Joh
    Sep 13 at 22:33
  • \$\begingroup\$ Try disconnecting the two channels, then driving with only a single channel. And turn the volume up as far as possible. \$\endgroup\$ Sep 14 at 0:56
Your signal averages at 0VDC, it does not rectify and filter the input signal. Then the average brightness is with its input at 0VDC. You need a "peak detector" which rectifies the signal and filters the resulting DC voltage that represents the loudness of the input signal. Here is my peak detector: peak detector
