Some products I've seen attach PCBs with a solder-able type of ribbon cable on a 0.1" pitch. What is this called? Is there an example at Digikey?
This ribbon cable is used for direct board to board (no connectors) and is soldered into a single inline pin pattern on 0.1" pitch. It also needs to be high temperature since it is soldered, not the PVC of 'typical' ribbon cable that melts.
TIAenter image description here
  • \$\begingroup\$ Its definitely 0.1" pitch and you can solder it directly into the holes for a single inline pin pattern. The photo was from shop.pedalparts.co.uk/… - but their term "direct connect ribbon" isn't the standard. \$\endgroup\$
    – brainfog
    Commented Sep 15, 2021 at 0:23
Here is an example from digikey (Part no.: 3M156019-100-ND). This is a solid core flat ribbon cable like your picture.
FPC and FFC cable are flex circuit board with traces for the "wires". They're different from what your picture shows.
  • \$\begingroup\$ When I search digikey for that term I get 25 mil pitch 30 awg. I'm after something probably around 20 awg on a 0.1" pitch. \$\endgroup\$
    – brainfog
    Commented Sep 15, 2021 at 0:26
Looks like on Digikey it is under the category of : Flat Flex Ribbon Jumpers, Cables
Here is an example: https://www.digikey.com/en/products/detail/te-connectivity-amp-connectors/FST-22A-5/5399439
https://www.digikey.com/en/products/filter/flat-flex-ribbon-jumpers-cables/457 Then select 0.1" pitch
Newark calls it what I would expect "Ribbon Cable, Board to Board Jumper" https://www.newark.com/molex/25001-0802/cable-assy-8pos-50mm/dp/25M1993
    \$\begingroup\$ Flat-flex is not what you want. \$\endgroup\$
    – Hearth
    Commented Sep 15, 2021 at 4:27
