I looked up what a good voltage and current would be good for my strip and happened to have what the power supply itself is labeled as a class 2 power supply. It outputs 12V at 500mA DC. The strip is bright but not overheating, so I think it is about right.
The problem is that I use a powerline ethernet adapter from Netgear and when the strip is plugged in (in a separate plug from the adapter, on the same home circuit,) my internet connection becomes terrible. Does anyone know what's causing this and how to fix it?
I thought that the powerline adapter worked along the ground so it seems odd to me that the power supply with no ground pin (only the two standard US prongs) would affect it, but then again it really does happen only when the light is plugged in and I don't know much about this stuff.
New contributor
Frizan is a new contributor to this site. Take care in asking for clarification, commenting, and answering. Check out our Code of Conduct.
  • \$\begingroup\$ Perhaps your powerline ethernet adapter from Netgear is too weak to light up the led stripe. Do you have link to the Netgear adaptor? \$\endgroup\$
    – tlfong01
    Sep 15 at 1:11
The ground pin is tied to neutral at the breaker box, so it is perfectly possible for noise injected into the neutral wire to appear on the ground wire as well.
Beyond that, most recent (not slow) powerline ethernet adapters use 2x2 MIMO, and utilize both line to ground and neutral to ground as the two MIMO pairs. If your adapter has 3 prongs, you can safely assume it is using all 3 conductors to transmit data.
Now, as to what is causing your degraded speed, it is the LEDs. Unfortunately, LEDs when powered from switching converters (like your little 12 V 500 mA brick almost certainly is) are far from ideal loads. Their exponential V-I curve (current draw unusually sensitive to voltage variation) along with their parasitic capacitances generally interact particularly poorly.
What you get is a perfect storm of wideband harmonic noise that gets injected back into the AC mains and the spectrum of this noise is particularly heavy in the 150 kHz to 30 MHz band - the same band that is used by powerline networking.
In fact, it is so bad that according to this research paper, just three 1 W LEDs powered in this manner can cause a 0 dB SNR condition in the frequency band used by powerline networking. In other words, if your signal is merely degrading in speed, you're doing pretty well, considering there is potential for the noise to be so severe so as to cause the connection to drop out entirely.
You have a few options, though without buying a spectrum analyzer to get a peek at the actual spectrum of the noise, it is difficult to know what solution might yield the best results. The main issue is that noise in this band tends to be difficult to filter out for the same reason that powerline networking likewise uses this frequency band - it is hard to block.
That being said, your degraded connection indicates that your SNR is dropping but isn't so low that there isn't hope. You just need to attenuate the noise getting injected some, and you'll see an increase in speed as you attenuate the noise more and more.
I'm going to list some solutions in order of easiness. And they can be used together for extra effect. Doing one might be enough, or you might find that nothing you do can mitigate the impact on your connection speed to your satisfaction. Like I said, it is hard to say without taking some measurements. But with some luck, you might even get away with just the first item on the list:
1. Use an extension cord. Yep. Just plug the LEDs and their power brick into an extension cord. The longer the better. The inductance will help attenuate the high frequency noise some, and the longer the cord, the more the attenuation. It might help or it might do very little but it is so low-effort, might as well try, right?
2. Put it on a different circuit. If you're clever, you can double up with #1 by using a extension cord to plug it in to a different circuit (but keep the LEDs where you want them).
3. Add some ferrites. Search for cable ferrites on Amazon or your online vendor of choice, they are widely available. They clip around the power cord (or better still, extension cord) of the supply powering the LEDs. Put an additional one so there are ferrites on opposite ends of the cord for more attenuation.
4. Add an RFI filter. It can be difficult to know how well these will work, but it will work better when used with cable ferrites than alone. These are also widely available on amazon, though usually you will have to wire directly through them. You can find similar ones that have a proper plug and outlet by searching for power conditioners. Ones that specifically mention 'RFI' as opposed to just 'EMI' filtering will probably work best (RFI implies higher frequency filtering), but a regular EMI filter will help to some degree.
5. Just try a different power supply. This isn't the hardest, but I put it last because it probably won't help. It is worth a shot though. Unless... you have an old non-switching wallwart laying around somewhere. You know the kind, big, heavy, ugly, from the early 1990s. The important point is heavy. A 12 V one of these might cure your problem completely - inside they have a big old 60 Hz transformer and a bridge rectifier and a filtering capacitor. These won't cause the high frequency harmonics when powering the LEDs, but they also might have poor regulation, and could shorten the life of the LEDs. And the LEDs will flicker. At 60 Hz. Like fluorescent lights. This is item 0 because it is an option but probably not one you want.
Good luck! You might just get away with the extension cord trick. Definitely give that a try if you have one that isn't being used. Your mileage may (will) vary though.
@metacolin is generally right, but my first action would be to throw away the LED PSU and get a better one.
The powerline ethernet works by injecting high-frequency currents into the power line. It takes care not to inject much, because for other devices this accounts for lowering the power quality. This is why it is easily affected by powerline noise.
The power adapter works internally by creating high-frequency currents and SHOULD take care not to inject them neither into the power line, nor into its 12V output.
If it does, it is not because it needs to, but because it is of pretty much low quality.
This low quality could manifest not only by the high-frequency noise, but by other important things like, e.g. poor fire safety. Or just wait until your power company finds out that something interferes with your power meter (well, this is less probable).
I am sure you do have more than 10 devices in your house that have either internal switching-mode power supply, or an external "power brick" that is generally the same. Including, in the first place, the computer you use your Internet connection with and the powerline ethernet adapters themselves. None of them interferes with your connection, does it?
p.s. if at all possible, get rid of the powerline ethernet as well. A can full of worms in itself, it is.
Frizan is a new contributor. Be nice, and check out our Code of Conduct.
