New to CANbus and just wondering about something. I want two nodes connected with CANbus. They have different MCU, transceivers and so on. Question is, can I just connect these on the same wire? (see picture 1)enter image description here
If not, how is that different to this (see picture 2)?
They have the same bit rate.
    \$\begingroup\$ It depends what lengths those wirings are. We can't know if it is within specs or not. \$\endgroup\$
    – Justme
    Sep 16, 2021 at 9:34
  • \$\begingroup\$ can i just connect these... probably not. Details needed. \$\endgroup\$
    Sep 16, 2021 at 9:46
  • \$\begingroup\$ Thank you for answering. The bus is within its requirements. The wire length from node 2 is the same length as node 1 +- 1 centimeter. \$\endgroup\$
    – Ben
    Sep 16, 2021 at 9:48
    \$\begingroup\$ @Ben yes, but this is not about difference in length between two nodes, it is the absolute lengths of wires. The stub from the linear bus to Y connector, and from Y connector ports to nodes 1 and 2. \$\endgroup\$
    – Justme
    Sep 16, 2021 at 10:25
  • \$\begingroup\$ @Justme Thanks again for responding. I will like to point out that i'm connecting Node 2 to a already working system. I just want to "hop on" the same connector as Node 1. \$\endgroup\$
    – Ben
    Sep 16, 2021 at 10:52
It depends on the cable length from the "multi-drop" bus to the physical nodes. This is called a "stub" and the maximum acceptable stub length on classic high speed can is 0.3m, though slightly longer is ok for the lower baudrates.
Notably, your schematic also lacks a signal ground, which must also be routed to every node in addition to CANH and CANL.
See What are the most common causes of CAN bus communication errors? for a summary of common problems like this.
  • \$\begingroup\$ Thanks for your answer. To make it more understanding: the bus i want to connect on is already a working system. i just want to add one sensor, and its very close-by to another sensor. So the system is functional and working. The system is SAE J1939, so speed is between 250-500 kbps. \$\endgroup\$
    – Ben
    Sep 16, 2021 at 9:52
    \$\begingroup\$ @Ben Maximum recommended stub length is still around 0.3m then. And you still need a signal ground. \$\endgroup\$
    – Lundin
    Sep 16, 2021 at 13:50
  • \$\begingroup\$ @DavideAndrea No, CAN is a 5 wire bus where shield and V+ are optional. Fundamental electronics knowledge gives that for example your PC and a car will not necessarily have a voltage potential difference that's within the spec of the CAN transceiver. Which is +/-58V on modern CAN transceivers like MCP2562FD and far less on older ones like TJA1050 or MCP2551. Thus we need a signal ground or the communication might fail. \$\endgroup\$
    – Lundin
    Sep 21, 2021 at 13:54
    \$\begingroup\$ @DavideAndrea There also exists a quackery myth that you don't need to have signal ground across nodes located on the same vehicle, but people saying such cannot possibly have worked with automotive electronics in a professional setting, since the chassis ground is noisy as f*** and can't be used as signal reference, because that ground will be shared with starters, alternators, valves and all other evil things that could be found on some generic vehicle. \$\endgroup\$
    – Lundin
    Sep 21, 2021 at 13:56
  • \$\begingroup\$ OK, I looked up in ISO 11898-2, "Road vehicles — Controller area network (CAN) — Part 2: High-speed medium access unit" iso.org/standard/67244.html. It says: "two-wire cable, relative to a common ground". You are correct, I stand corrected. \$\endgroup\$ Sep 21, 2021 at 15:15
