10
I would like to hand wind a smps transformer for prototyping work. The specs of the transformer are as follows :
Transformer Parameters
Core Material: EE16, NC-2H or equivalent, gapped for ALG of 88.55 nH/t² Bobbin EE16, Horizontal, 10 pins, (5/5)
Winding Details
Shield: 15T x 3, 35 AWG
Primary: 105T, 35 AWG
1st Half Bias: 6T x 4, 30 AWG
2nd Half /Feedback: 6T x 4, 30 AWG
Secondary: 7T, 22 TIW
Winding Order
Shield (2–NC), Primary (4–1), Bias (5–3), Feedback (3–2), 5 V (10–8)
Primary Inductance 1.074 mH, ±10%
Primary Resonant Frequency 1000 kHz (minimum)
Leakage Inductance 95 μH (maximum)
I have procured EE16 core, bobin and the copper wires. Can anyone explain me how to actually go about winding this one? specifically:
  1. Which direction to start each winding CW / CCW ?
  2. What to do in cases where turns are very less to fill one layer?
  3. I have seen another transformer design where there were parallel coils connected to same terminals, In this case do we turn both coils side by side or on different layers?
  • \$\begingroup\$ Is this for hobby work? Just curious :) \$\endgroup\$ Feb 21, 2013 at 8:48
  • \$\begingroup\$ Yes, We are designing a custom power supply for a robotics project. \$\endgroup\$
    – srinathhs
    Feb 21, 2013 at 9:14
1) Winding direction doesn't matter as long as you keep it consistent. If you are adapting a lathe or drill as a winder, the winding direction will be determined by the machine.
2) If the small windings are at approximately the same potential they can share a layer, otherwise you must provide sufficient insulation between them. Sometimes you may have to separate layers to reduce capacitance between them, or interleave them to reduce leakage inductance, but that is too complex to discuss here.
3) Winding coils side by side is simpler and provides better voltage isolation especially when the sections are different bins on the bobbin. That is essential for high voltage supplies and makes mains voltage safety approval easier.
However it increases the leakage inductance, and that matters for high frequency applications like SMPS. The only reasonable way to know if you can do this is to wind one that way and measure the leakage inductance. If it's out of spec (or even close to it) wind another in layers and compare them.
  • \$\begingroup\$ Thank you, I have few more doubts, by consistent winding direction do you mean use same direction for all coils ? and is there any webpage which gives more details on this ? I am particularly looking for practical winding instructions. Also how to translate "coupling dots" in transformer diagram to actual winding ? \$\endgroup\$
    – srinathhs
    Feb 21, 2013 at 10:18
  • \$\begingroup\$ Yes, normally same direction for all coils makes life easier when working out which end of a winding should have the dot. \$\endgroup\$
    – user16324
    Feb 21, 2013 at 10:21
  • \$\begingroup\$ Thanks!!, Any link / book can u refer me to get into much more details on practical designing ? \$\endgroup\$
    – srinathhs
    Feb 21, 2013 at 10:41
  • \$\begingroup\$ I use this book amazon.co.uk/… but that probably doesn't help you much! \$\endgroup\$
    – user16324
    Feb 21, 2013 at 10:48
    \$\begingroup\$ I can not point to them off the top of my head, but when I first began designing flybacks (assuming that is what yours is due to the air gap) I found some TI and other companies app notes very helpful, they covered the design, losses and winding practices that Brian mentioned. \$\endgroup\$
    – MadHatter
    Dec 3, 2015 at 14:20
