I'm using the IR2104 gate driver in a DC motor driver design, and I noticed something in functional block diagram from the datasheet that I didn't understand.
The low side schematic is as expected, but the high side has lots of extra parts, including a pulse generator, pulse filter and SR Latch. I would have thought that the high side could be connected similar to the low side, but with an inverted output signal so that it has the opposite logical output from the low side.
From what I've read it seems that this extra circuitry is for bootstrapping and giving high-side bias, but I'm not sure what is meant by high-side bias and don't know what the goal of this is and why it is necessary.
An explanation of what high-side bias is and its purpose here would be really appreciated since I'm a bit lost.
For reference: IR2104 Datasheet
