That is a current source. It will be a sub-circuit to generate a reasonably constant current through the push-pull output transistor biasing circuit.
To avoid cross-over distortion (a discontinuity on the changeover from sourcing current through the upper transistor to sinking current through the lower transistor) on the output the diodes are added to compensate for the voltage drop across each base-emitter junction. Running a constant current through these keeps the voltage drop across them reasonably constant.
