I'm trying to learn VHDL and and trying to create an 8 bit 4 to 1 MUX. Below is my code:
LIBRARY ieee;
USE ieee.std_logic_1164.all;
PACKAGE inputarray_type IS
TYPE inputarray IS ARRAY (3 DOWNTO 0) OF STD_LOGIC_VECTOR (7 DOWNTO 0);
END PACKAGE inputarray_type;
USE work.inputarray_type.all;
ENTITY bit8mux4to1 IS
PORT (inputs : IN inputarray;--ARRAY (3 DOWNTO 0) of STD_LOGIC_VECTOR (7 DOWNTO 0);
s : IN STD_LOGIC_VECTOR(1 DOWNTO 0);
output : OUT STD_LOGIC_VECTOR (7 DOWNTO 0));
END bit8mux4to1;
ARCHITECTURE structure OF bit8mux4to1 IS
COMPONENT mux4to1
PORT(i0, input1, i2, i3, s0, s1 : IN STD_LOGIC;
output : OUT STD_LOGIC);
BEGIN
generate_mux: FOR i IN 0 TO 7 GENERATE
stage0: mux4to1 PORT MAP (inputs(0)(i), inputs(1)(i), inputs(2)(i), inputs(3)(i), s(0), s(1), output(i));
END GENERATE generate_mux;
END structure ;
The component mux4to1 works, and I've used it as a component in other code.
When I try to compile the code I get an error saying
"VHDL syntax error at bit8mux4to1.vhd(21) near text "BEGIN"; expecting "end"
I've tried changing the generate statement many ways and have tried commenting every line of the generate statement completely, but the error won't go away. What is the problem? Is there something wrong with the architecture?
end component;
before the architectureBEGIN
. Maybe a copy of the standard or at least the syntax BNF would come in handy? \$\endgroup\$
