I need a very simple, low noise Zener or LED voltage reference that will be fed by a potentially noisy (RF) voltage source.
Focusing on low noise, I was thinking of adding an LC filter before or after the reference to provide better RF filtering.
I also considered the possibility of using a high resistance series inductor in place of the equivalent resistor. Any idea how this might behave?
One advantage I see is that high DCR inductors have much higher inductance for lower cost and size compared to low DCR ones, and resistance is needed for LED/Zener current limiting anyway.
