I've loaded the crimp terminal two different ways in my crimper, but I haven't the experience to say which is correct.
Cursory web research doesn't seem to answer the question.
Edit: this is the first halves of butt connectors. The other halves aren't crimped yet. (The UI here wouldn't let me upload the whole photo.)
two crimped connectors, one on a black wire and one on a white wire
  • \$\begingroup\$ the left one, because it did not mash the wire \$\endgroup\$
    – jsotola
    Sep 22, 2021 at 0:16
The one with the white cable. Remove the red plastic to see why. The copper is contacted in the middle, and there's a small tube that you simply have to squeeze. At the end however there's two flaps that need to be bent inside to stick on the cable insulation.
    \$\begingroup\$ Exactly. You should always make test crimps and do an autopsy on them. You'll learn quickly what works and what doesn't. \$\endgroup\$ Sep 21, 2021 at 22:57
