I just started to use EAGLE (9.6.2 free version). I am watching someone. When he makes the ground connection, his board's ground doesn't connect with wire but my GNDs are connecting together. Is it a problem? If it is how can I solve that? I mean yellow wire is going over pins. Are pins involving GND?
  • \$\begingroup\$ With a mouse right-click you can rotate symbols (like gnd) as you place them. This will make your layout prettier. \$\endgroup\$ Sep 23, 2021 at 7:16
  • \$\begingroup\$ Please clarify your specific problem or provide additional details to highlight exactly what you need. As it's currently written, it's hard to tell exactly what you're asking. \$\endgroup\$
    – Community Bot
    Sep 23, 2021 at 7:46
  • \$\begingroup\$ By the way, the ESP32 is not very happy if you don't add some external decoupling caps. If you start all the radios (WiFi and BT) at the same time, it may reset. Because you are doing the PCB, please add some big ceramics caps (22uF) close to the VCC pins of the ESP. Just in case. It costs nothing to not mount them at the end. But it's very annoying to realize afterward that you need them and you haven't planed any spare footprint for them.... just a quick tips... \$\endgroup\$
    – Blup1980
    Sep 23, 2021 at 8:20
  • \$\begingroup\$ @Blup1980 I will use esp01 like this tr.aliexpress.com/item/32341788594.html . Raspberry pi pico provide 3.3 GPIO pin so I don't need to add resistor but I heard caps first time. You are saying I need to add 2 Caps on Esp01's vcc pin right ? \$\endgroup\$ Sep 23, 2021 at 8:38
  • \$\begingroup\$ Yes, it's better to add additional capacitors between the VCC pin of the ESP and GND. If your tests shows that you don't need them, don't solder them. The PCB won't become more expensive if you anticipate a footprint for theses caps. (ceramic, not electrolytic !) \$\endgroup\$
    – Blup1980
    Sep 23, 2021 at 8:45
Where is the problem here? Same Nets (Same Name) get connected together. If you want to split grounds, use diffrent symbols for each rail.
  • \$\begingroup\$ In board design yellow line goes over the pins , I though that is the problem (isn't it ?). When he do that his yellow line 's are not connecting with yellow line. \$\endgroup\$ Sep 23, 2021 at 7:06
    \$\begingroup\$ You see: These so called airwires are the connections still to be routed in the layout. Just click on one. It will highlight all the pads (gnd in this case) that need to be connected together - all the others are not affected. \$\endgroup\$ Sep 23, 2021 at 7:10
  • \$\begingroup\$ When i click Show on schematic and then Esp's GND's green line ,only GND's are shining. Okay I get it. In board even yellow line goes over pins it doesn't mean it involves pins. Right ? \$\endgroup\$ Sep 23, 2021 at 7:17
    \$\begingroup\$ correct! You got it. Type 'show gnd' in the command line in board view. Or click on the 'route' symbol and then click on an airwire. \$\endgroup\$ Sep 23, 2021 at 7:21
  • \$\begingroup\$ Thank you @ElectronicsStudent \$\endgroup\$ Sep 23, 2021 at 7:34
