I have a surplus Microsemi MO9072 24GHz gunn transceiver (Datasheet) and a matching MDT86552 horn antenna (Datasheet) that I'd like to use in a project. In the same package was a waveguide of some form that clearly could fit between the antenna as photographed below that I can't find any details on, it was purchased many years ago.
Doing some bench testing it didn't seem to make a difference, possibly because the distances were too small, so I'm wondering the purpose of the plate and whether it should be used with the horn antenna or instead if it's only intended for use without an antenna for short range applications?
For testing I supplied the gunn diode with 5V DC from a linear bench supply with a 10uF tantalumn in parallel and connected a 1X scope probe between ground and the the mixer B which is described as for motion sensor. Then I was taking a few steps backwards and forwards and could see some movement and the amplitude seemed similar between both times, I've since used the scope for something else but believe I was using 1mV per division.
  • \$\begingroup\$ can you please add details of your bench testing. How did you connected them together. \$\endgroup\$ Feb 22, 2013 at 6:37
  • \$\begingroup\$ Sure just added that, it wasn't a very scientific test just mainly wanted to make sure it appeared to be working before taking it any further and looking at adding an amp. \$\endgroup\$
    – PeterJ
    Feb 22, 2013 at 6:54
From the shape of the depicted plate, that is an E-field capacitive iris to be inserted in a specific physical location in the waveguide between the electronics and the antenna. If the waveguide is a transmission line, the capacitive iris is basically a capacitor shunting the transmission lines at that physical distance along the line. Typically this is done to create better impedance matching such as to cancel an "inductive" type of mismatch effect so that the transmitter / receiver is better impedance matched to the antenna at a particular operational frequency. They likely wouldn't have included it if it were not meant to be used and make an improvement in the matching. The only reason it wouldn't be used is if there was an alternative type of antenna that it was to be used with or if there's a very different frequency band option that the transceiver is able to be used with such that it is to be used in one configuration and not the other. Typically you'd just use it as is. Besides matching improvement it could also help to filter out out of band interfering signals either from propagating from the antenna to the transceiver or from the transceiver to the antenna. You wouldn't likely see much improvement in a short range bench test but if you were operating at long range near the limit of the equipment such that you might notice a 1dB or so improvement then you'd more likely notice a difference.
It could also be useful to create a known and purposeful mismatch or to increase the resonant cavity Q by decreasing its coupling to the antenna if it were useful in the desired configuration to get a little more of the GP's own signal reflected/resonated back into the GP unit cavity though that depends on the unit's design and purpose.
Edit -- on second look since that has a capacitive E-field gap ("capacitor") as well as "rounded" loops ("inductors") at the H-field inductive ends, and it looks to be in a conductive (copper, brass, maybe silver plated) plate that plate's iris also could work like an LC resonant lumped element filter so it could be useful in that capacity to provide signal bandwidth filtering as well as the above possible explanations. The Q and center frequency precision could be relatively high, maybe in the hundreds or less by my guess.
That could help get the GD oscillations going, provide Q related tuning / selectivity, and help set the S11, S21 in the transceiver's band according to the above matching and resonance concerns.
