I would like to know what the max current consumption of the W5500 module is so I can size an appropriate voltage regulator. When I looked into the datasheet I have found something that made me second guess.
Under the absolute maximum electrical characteristics of the datasheet
It is stated that the max current consumption of this chip is 5mA, so I assumed that that is it.
but when i scrolled down I find this
So which one is it? It is written under "Power Dissipation" given with what the absolute maximum rating say, I can only surmise that that current is coming from somewhere else
    \$\begingroup\$ this is a pretty crap datasheet, and the hardware design guide is no better (wizwiki.net/wiki/doku.php/…). From these documents, its impossible to say with certainty what the absolute maximum power draw is. I would either contact them, or, if thats impossible, design for the max typical plus 50%, although even that could be wrong. The correct thing to do here would be not to use a chip from such a crap vendor \$\endgroup\$
    – BeB00
    Sep 24 at 19:35
    \$\begingroup\$ They say here that the value is typ+10% (forum.wiznet.io/t/topic/3453/4) but not sure if i really trust such a half assed company \$\endgroup\$
    – BeB00
    Sep 24 at 19:36
  • \$\begingroup\$ @BeB00 Sadly nothing i can really do here since this what arduinos uses, i do not know how to write my own library for a custom 100MBPS ethernet. ill just use a 300-500mA regulator then, since my digital cicuit really needs less than 10mA, 300mA regulators are cheap anyway. \$\endgroup\$
    – DrakeJest
    Sep 24 at 19:53
The "Absolute Maximum Ratings" are not meant to represent performance, but conditions under which the device won't break. The 5mA appears to be an input current, not a supply current...it's the amount of current you can force into an input before it fails. I think if you plan for 132mA, and specify a 200mA supply just to have some overhead, it should be fine.
  • \$\begingroup\$ Also the output currents are per output pin. The Power Dissipation figures are the ones you need (although they actually list current rather than power). \$\endgroup\$
    – Frog
    Sep 24 at 20:59
