-5
Does the MOSFET gate need a high voltage in order to turn on the MOSFET as well?
What is the difference of high and low side of MOSFET? Is there any effect?
  • \$\begingroup\$ I think your question relates to the use of a N-mosfet as a high side switch (controlling the positive side of the load). If that is the case refer to this reply for the problems it introduces. \$\endgroup\$
    – alexan_e
    Commented Mar 16, 2014 at 16:05
High-side switching is when the load is between the drain and the supply, low-side switching is when the load is between the source and ground.
