Here's a diagram of a microcontroller IC, with four outputs. The top two outputs OUT1 and OUT2 are sinking current from Vcc (via R1 and R2), and the bottom two outputs OUT3 and OUT4 are sourcing current to ground (via R3 and R4):
"Is" represents the current drawn by the microcontroller to perform its operations, and does not include any current sunk or sourced by any of its inputs or outputs. On a datasheet this might be labelled "supply current".
OUT1 is being held low by the microcontroller, causing a voltage drop across R1, and resulting in current flowing down through R1, into the IC. Kirchhoff's Current Law tells you that this current must emerge at the GND power supply pin of the microcontroller.
OUT2 is high, at Vcc, causing no potential difference across R2, and no current.
OUT3 is low, at 0V, so there's no voltage across R3, and no current.
OUT4 is high, causing a voltage drop of Vcc volts across R4, and current flows out from the IC and down to ground through R4. This current is being sourced by the IC from its own positive power supply pin.
Using Kirchhoff's Current Law, we can make the following statements:
Current exiting (being sourced) at the IC's inputs and outputs must originate (enter) the IC via its positive supply pin, so current there will be the sum of all such currents and its own operating current.
Similarly, current measured at the IC's "ground" power supply pin will be the sum of all currents entering the IC (that the IC is sinking) via its inputs and outputs, plus its own operating current.
Edit: Supercat made a good observation in this answer's comments, that current leaving or entering this IC could be via another IC's input or output. Where I have put resistors in this example, you could equally imagine inputs or outputs of another IC. The resistors are there to illustrate possible current paths, but you could just as easily follow a current path into the Vcc pin of one IC, out of one of its outputs, into the input of another IC, and out of this second IC's ground pin. Here's a picture I've borrowed from this answer, showing how you might visualise the currents in a more complex scenario involving 2 ICs, and a transistor:
It might help to get an idea of how typical push/pull outputs work, and see how they sink and source current from/to their supplies. See this answer. It refers to the outputs of op-amps, but the principle remains the same.
Note that the power supply itself must be supplying all these various currents, and they must all return to the same voltage source. I've labelled these currents at the power supply nodes Vcc and GND, to illustrate this.
Your question is:
Will the net current drawn by a microcontroller equal the current supplied by it?
The answer is: Yes, if you include the device's own supply current, both in (from Vcc) and out (to GND).
A more complete answer is: Kirchhoff's current law tells us that the total sum of all currents entering the IC (via its positive power supply pin and any input or output pins sinking current) must equal the total sum of all currents leaving it (via its ground supply pin and any input or output pins sourcing current).
