I have a discrete linear system that reads as follows: $$ x_{i+1} = A x_{i-1} + Bu_{i-1} \\ y_{i} = C x_i + Du_{i} $$ The first equation is supposed to denote the discrete time evolution of some system (a continuous system sampled periodically and the index then corresponds to the sample number) and the latter equation is supposed to denote the output an experimenter reads. The second summand denotes a control function applied to the system.
I am given to understand this is something standard in EE and control theory.
My question is the following: How can I derive the transfer function of the theory using what apparently is called a discrete z-transform (and is it true this is an analogy to Laplace transform)?
I apologise if the question is trivial but my background is in differential topology and not engineering.
