I need to drive a pair of N channel MOSFETs, one on the high side of the load and one on the low side of a load. Most ICs I can find for this application require 10V+ supply voltage to get the the chip to fit in recommended operating conditions.
The VCC at the top side of the N channel is a LiPo, single cell battery (~3.2 to 4.2 V).
The inputs into the driver needs to operating around 3.3V (from outputs of a micro controller), to complicate the requirements even further.
Does anyone know where I can find such an IC? The high side/low side does not necessarily need to be in a single package. The current draw from the MOSFEts are about 3A at VCC.
Any suggestions?
I think this MIC5014 driver chip will work for you
