Can anyone explain the difference between the two codes below. Both written in Verilog, Xilinx. If someone can explain how the second one works would much appreciate it.
module decoder_24(in1, in2, out1, out2, out3, out4);
    input in1,in2;
    output out1,out2,out3,out4;
    assign  out1 =!(!in2&!in1);
    assign  out2 =!(!in2&in1);
    assign  out3 =!(in2&!in1);
    assign  out4 =!(in2&in1);
endmodule
module multiplexer41_4bit(input0, input1, input2, input3, sel0, sel1, out);
    input [3:0] input0,input1,input2,input3;
    input sel0,sel1;
    output [3:0] out;
    //multiplexer0
    multiplexer_41 M41_0(input0[0],input1[0],input2[0],input3[0],sel0,sel1,out[0]);
    //multiplexer1
    multiplexer_41 M41_1(input0[1],input1[1],input2[1],input3[1],sel0,sel1,out[1]);
    //multiplexer2
    multiplexer_41 M41_2(input0[2],input1[2],input2[2],input3[2],sel0,sel1,out[2]);
    //multiplexer0
    multiplexer_41 M41_3(input0[3],input1[3],input2[3],input3[3],sel0,sel1,out[3]);
endmodule
Second:
case({m_sel2,m_sel1})
    2'b00: m_out = m_in1;
    2'b01: m_out = m_in2;
    2'b10: m_out = m_in3;
    2'b11: m_out = m_in4;
    default: m_out = 1'b0;
endcase
    \$\begingroup\$ do you have the code for the multiplexer_41 module? \$\endgroup\$ – The Photon Feb 22 '13 at 18:08
  • \$\begingroup\$ I am trying to post it but the it comes out in a very bad format for some reason. will try to fix it and send it over soon \$\endgroup\$ – sotiris Feb 22 '13 at 18:41
  • \$\begingroup\$ case({m_sel2,m_sel1}) 2'b00: m_out = m_in1; 2'b01: m_out = m_in2; 2'b10: m_out = m_in3; 2'b11: m_out = m_in4; default: m_out = 1'b0; endcase \$\endgroup\$ – sotiris Feb 22 '13 at 18:44
    \$\begingroup\$ @sotiris - Use the edit button to add the code to the original post. You're currently adding it as a 'comment', which has a different purpose. \$\endgroup\$ – Tim Feb 22 '13 at 20:24
  • \$\begingroup\$ nice one Tim. quite new here \$\endgroup\$ – sotiris Feb 22 '13 at 20:28
Your first module, decoder_24, is a decoder. It has 2 inputs and 4 outputs. It asserts exactly one of the outputs, depending on what combinations of inputs is asserted.
Your second module, multiplexer41_4bit, is a multiplexer. It has 4 data inputs, 2 select inputs, and one output. The data inputs and the output are each 4 bits wide. Depending on what combination of select lines are asserted, the one of the data inputs is passed through to the output.
How it works, is there's 4 single-bit multiplexers in parallel. Each one is controlled by the select lines, and has its data inputs connected to one bit of each of the 4 data inputs and its output connected to one of the bits of the output. As for how the one-bit multiplexers work, you need to look at the multiplexer_41 module to find out.
  • \$\begingroup\$ Thank you. Helpful comment. However still kinda lost you at the end. I think if you try to explain me what the numbers in the brackets mean will get it. for example at the line below what number 3 represents? input0[3] \$\endgroup\$ – sotiris Feb 22 '13 at 18:40
  • \$\begingroup\$ When you declare input [3:0] input0, you are saying that input0 is a bus with 4 wires. The individual wires are input0[0], input0[1], etc. \$\endgroup\$ – The Photon Feb 22 '13 at 18:57
  • \$\begingroup\$ @sotiris That's the index of the bit that you're passing (zero based of course). \$\endgroup\$ – Jeff Langemeier Feb 22 '13 at 18:57
endcase
Lets consider, that all signals (m_sel2, m_sel1, m_out, m_in1, m_in2, m_in3, m_in4) are 1 bit long.
Tnen {m_sel2,m_sel1} - is concatenation of two signals m_sel2 and m_sel1. If m_sel2 = 1'b0 and m_sel1 = 1'b1, then {m_sel2,m_sel1} will be equal to 2'b01.
Case statement synthesizes into a multiplexer. If think for a while about how case works - you will find, that it is pretty much the same as mux.
As for the realization: Case statement is a Behavioral Statement, and it must be inside Procedural Block. So I added some minor code:
module mux_4x1(m_sel2, m_sel1, m_in1, m_in2, m_in3, m_in4, m_out);
    input m_sel2, m_sel1;
    input m_in1, m_in2, m_in3, m_in4;
    output reg m_out;
    always @(m_sel2, m_sel1, m_in1, m_in2, m_in3, m_in4)
    begin
        case ({m_sel2, m_sel1})
            2'b00: m_out <= m_in1;
            2'b01: m_out <= m_in2;
            2'b10: m_out <= m_in3;
            2'b11: m_out <= m_in4;
            default: m_out <= 1'b0;
        endcase;
    end
endmodule
So I went a little bit further and made simple project in Altera Quartus II. I think, that with Xilinx FPGA there will not be much differences.
After building a project we can see the result in a rtl-viewer.
Compilation Summary tells us, mux project uses 2 4-input LUTs. For better understanding about how mux is created on LUTs, you can look at this:
Here LUTs functions are represented as scheme.
I hope that I did not confuse You even more!
