I plan on having the following array in my system:
Vmpp voltage at max. power point for each cell is 1.67 V
Impp current at max. power point is 18.4 mA
As the number of cells in the right "Parallel String" is greater than the one on the left, is it ok to assume that the final array Impp current will be somewhere around 92 mA (18.4 mA * 5) and the Vmapp voltage will be 3.34 V (1.67 V * 2,) or do I need to use the parallel string with less cells for this calculation?
I need at least two cells in series to have the voltage for the SPV1040 MPPT IC and would like to use all available space on the board, this is why I have a maximum of 9 cells.
EDIT: Here is the link for the solar cell's datasheet
