I'm working on a project that runs on 12V DC. The power comes via PoE, which induces a hard limit of 15 watts on the design.
The circuit is intended to drive multiple loads that are rated for ~7W each, but only sporadically and only a few seconds at a time. However, it's likely that multiple loads activate simultaneously, which can draw up to 120W. The loads can run at 12-24V ± 10%.
The solution I'm considering is adding a battery or supercapacitor in the circuit. (This is similar to this question but with a higher power disparity.)
  • Would a supercapacitor or a battery (likely lead acid) be better suited for this application? I've found ~60F supercap arrays that could easily drive 120W for 10 seconds while only dropping a couple volts, but a battery would be much cheaper.
  • Would a diode and power resistor in series be sufficient for limiting the PoE current draw?
    • Is there another relatively simple solution that would allow faster charging, but still gracefully handle a startup with an uncharged capacitor?
suggested circuit
    \$\begingroup\$ The latest PoE standard can support much higher power (up to almost 100 W, IIRC). \$\endgroup\$
    – Null
    Commented Oct 1, 2021 at 19:47
  • \$\begingroup\$ @Null Interesting. However, I'm limited by our existing PoE switches & cabling in this case. \$\endgroup\$ Commented Oct 1, 2021 at 19:49
  • \$\begingroup\$ I had a similar problem with my cameras. For one I purchased an adaptor that supplied the POE rather then the switch. It was not that expensive and is working great. You could possibly purchase a POE switch and parallel the power connections to get what you need. I am not sure if this would work as I do not know your setup. \$\endgroup\$
    – Gil
    Commented Oct 1, 2021 at 19:57
  • \$\begingroup\$ We need to know more about the loads. How will they react to voltage drops, etc. \$\endgroup\$
    – Drew
    Commented Oct 1, 2021 at 20:00
  • \$\begingroup\$ @Drew The loads can handle a volt or two of drop. They're specced for 12-24V, though. \$\endgroup\$ Commented Oct 1, 2021 at 20:12
