8
I've seen a couple similar questions, but nothing exact. I'd like to know how I can charge a laptop battery directly, meaning without the laptop. This would be a battery still intact, in good condition (not just a collection of cells).
I understand many laptop battery packs have circuitry built into them to protect from overcharging and over depleting. I don't know how advanced/accurate this would be, but it sounds promising at least.
Could it be as simple as buying a laptop battery like this and a physical wall charger like this and physically connecting the positive and negative connections, or would it involve building a controller circuit to sit in between them?
The goal in this case is to be able to utilize a small form-factor laptop battery pack as part of a portable ham radio setup. I could have one or more charged batteries available to me, swap them out as needed, and then charge them directly. I just don't want to buy a laptop to charge them.
  • \$\begingroup\$ Just a warning - if you don't build the charger correctly its generally quite easy to make the battery explode. e.g. handle communication errors with the battery pack in the most conservative way possible. \$\endgroup\$
    – Mark
    Feb 23, 2013 at 6:25
  • \$\begingroup\$ It would be "practically" cheaper to buy a laptop For charging, rather then building your own charger buy a laptop (will be cheaper than designing and building your own). Choose the best battery for midrange laptop. This is only a practical note, theory can have vast answers. \$\endgroup\$ Feb 23, 2013 at 6:47
    \$\begingroup\$ Why not use commercially available batteries that you can buy a charger for? Regular NiMH cells or LiPo cells as used in remote control models. \$\endgroup\$
    – jippie
    Feb 23, 2013 at 8:53
  • \$\begingroup\$ Just some ideas; Super or Ultra capacitors charge faster than batteries, more charge cycles, works under temperature extremes, no acid or corrosive chemicals. Just don't exceed the maximum voltage rating. I saw one on the bay, D-Cell size ~350 Farad 2.5 v (976 watt per cell), and yet others to 3000 Farad. "Power Tool" batteries may be an alternative. \$\endgroup\$ Feb 23, 2013 at 17:00
14
Look for a FAQ or pinout information online that pertains to the specific series of battery / laptop that is to be involved. The pinout and charging requirements vary significantly depending on the particular series of battery and laptop involved.
In general most laptops will use lithium ion cells similar to the 18650 type in the battery pack. The pack should be labelled or documented with its nominal DC output and/or charging voltage, nominal current ratings for discharge and/or charge, and similar usage information such as temperature limits et. al.
Typically you'd charge such a lithium ion cell to a maximum of 4.20VDC with a more conservative end of charge voltage being in the ballpark of 3.75V DC.
The pack will contain some number of series connected cell groups and each of those cell groups will have one or more cells in parallel at each stage. So a 4S1P pack will have 4 series connected elements with each element having 1P or 1 cells in parallel. A 5S1P or 4S2P or 3S1P pack configuration isn't impossible.
Generally if you take the nominal listed battery voltage (e.g. 15V) and divide by 3, or 4, or 5 and you get a voltage that's close to 3.75V or 4.20V after the division, that'll tell you the number of series cells in the pack due to each series cell being listed with that nominal voltage value and the pack voltage being the multiple of so many series connected cells.
You'll have a pack positive power connection, a pack negative power connection, and usually one or two connections for a NTC thermistor which is mounted adjacent to the cells for the purpose of monitoring the pack core temperature. Charging or discharging should not be done outside of the listed operating range, e.g. -10C to +45C or whatever, and the powered circuit should use that thermistor sense connection to verify that the cells aren't outside of those temperature ranges at all times when the pack is to be used.
There may also be a "smart battery" set of connections following the SMBUS smart battery specification protocol -- DATA, CLOCK, GROUND. These connect to a gas gauge / protection IC in the pack and that protection circuit provides two or more levels of protection for over temperature charge/discharge, under temperature charge/discharge, over current charge / discharge, over voltage charge, under voltage discharge, and related functions. If you operate the discharge and charge circuits within the limits set by the pack integrated protection IC you may be able to use the battery with a "dumb" load and charger so long as no protection limit is violated. If you violate some protection or safety limits the protection circuit may temporarily or permanently suspend or lock out either or both charging or discharging. For host/operator soluble conditions like an empty battery that is not unsafely undervoltage it'll usually just lock out discharge until charging is performed beyond some recovery threshold. To prevent overcharge it'll cut off charging current until the pack is discharged below a threshold etc. There are charge/discharge control FETS and fuses and a PTC protector and a current measurement sense resistor in series with the pack cells and your external pack power connection.
To maintain ideal safety and longevity you'll have to follow the pack's recommended and/or integrated protection / smart battery circuit's charge and discharge profiles as relate to temperature and charge / discharge current limits and state of charge. Look at the JEITA standard as well as the data sheets for common 18650 LiIon cells to get an idea about cases like high / low temperature charge / discharge, precharging, C/nnn rate charge and discharge recommendations, extended storage recommendations etc.
You may be able to access some of the details of the pack's information if you look up the safety certification test results for that pack model if those happen to be accessible.
Typically around 1A discharge currents and C/5hour charge currents (C = the mAh capacity of the pack) are reasonable. You'll generally charge at a constant current limit of say C/5 but also with a voltage limit of say N*3.75V where N is the series cell count in the pack. You can generally charge to 4.20V/series cell but that costs cell longevity and worsens storage life and recharge cycle life and makes it more likely you'll accidentally overcharge the pack if your constant charge voltage isn't precisely at or under 4.20V/cell.
See TI's web site for some gas gauge / protector product ICs like the bq20z75 et. al. to get an idea of what they do. If the pack supports it and your host can do so, using the SMBUS smart charging protocol will help you use the pack properly, though you may want to override its charging current and charging voltage limits with more conservative (smaller) values of your own.
More information --
Oh yes I'd forgot to mention that some packs have a system present line you'll need to ground to enable the pack to close its FETs. Some other packs go to sleep and perhaps open the charge / discharge FETs if the SMBUS data is inactive for too long and/or have no pull-up resistors.
  • \$\begingroup\$ 5s I've never seen and I really can't imagine anyone doing it, even though it's possible. 5s = 21V in commercial use plus headroom or a say 24V or so charger. Not impossible but not likely. As you say, less than a full 4.2V is a good idea BUT 3.75V is far far far too low. Even 4.1V gives substantially reduce capacity (but longer cycle life and 4.0V is ultra conservative Below that makes no real sense. // Industry norm is to charge LiIon at C/1 or about 2A for an 18650. Some few may spec C/2 but they are unusual. C/5 is unnecessarily low for LiIon - but will do no harm. // \$\endgroup\$
    – Russell McMahon
    Feb 23, 2013 at 8:22
  • \$\begingroup\$ Use of in battery protection to limit a dumb charger is a very very very (very) bad idea. || Normal LiIon Charging is to Vmax ay constant current and then hold at Vmax to allow current to taper down to some % of I max and then terminate. If you charge at CC to 4V1 and terminate there it will give the battery a very gentle time and give around 80% of full capacity. \$\endgroup\$
    – Russell McMahon
    Feb 23, 2013 at 8:25
Laptop Batteries have a number of Cells in series (either 18650 cells, or LIPO pouches). nominal 18650 voltage is 3.7V (Charged to 4.2V) so a 3S pack is 3 cells in series making 11.1V pack and 12.6V to charge. a 4S pack would be 4 cells in series 14.8V pack 16.8V to charge.
Usually there are 2 Cells or 3 cells in parallel to increase capacity, making a 2P or 3P pack as 6 Cell 11.1V pack would be 3S2P.
Because LION batteries are very sensitive to charging voltage, and variations in internal resistance and capacity over time, could mean charging the whole pack as a series string may over charge individual cells.
Laptops use Balance charging to Either Charge each Parallel group at 4.2V individually, or to bypass the fully charged cells with a resistor to continue charging the rest of the string.
Hence for a 6 Cell 11.1V pack, you would have the + and - connections, plus 2 more connections for the intermediate cells.
There is often a Thermistor in the pack as well giving another 2 connections. You can get Balance charges for Remote control vehicle batteries, but I suspect your cheapest/easiest option would be to use individual 18650 cells with a Battery holder a number of them to suit your capacity and voltage requirement and regular LION charger, then swap the cells out to recharge them.
You can get protected 18650 cells that individually prevent over charge/discharge. If you break open a laptop battery pack and use the unprotected cells, you will need a protection circuit to prevent over discharge, a quality charger will prevent overcharge of the individual cells. such as the XSTAR VP4
  • \$\begingroup\$ Welcome to stackexchange. Please make sure to correct spellings for future posts. \$\endgroup\$ Mar 1, 2015 at 1:13
