As shown in the above diagram , the same 2 coils of square are aligined with paralell of same plane .
$$ I:=\text{current which flows to each wire of the square } $$
What I am confusing to understand currently is about a force which acts against the wire A'B' made by BC and AD.
Using Biot–Savart law , the wire BC makes magnetic fields on points on A'B' . Each of the magnetic fields is in the same plane(this plane is perpendicualr to BC )
$$ \boldsymbol{ dF }_{}= I \left( \boldsymbol{ds}_{}\times \boldsymbol{B}_{} \right) \tag{1} $$
As we use right hand rule with the above formula , we can easily know that each cross product between \$~ I ~\$ of A'B' and that each magnetic field points upward of force vector .
Nextly we handle AD .
Each magnetic field is made on a point on A'B' by AD .
As we use eqn1 again , the vector of force points up upward again .
So by 2 straight wires of BC , AD , only the upward forces are made at A'B'
But the book states the below .
The currents of BC , AD are opposite hence the forces of 2 are opposite and be cancelled out
Where I've made (a) mistake(s)?
