I have a custom board with a STM32H7A3ZIT mcu. I'm programming it with a ST-Link V2 via SWD.
I'm trying to get an external hyperbus ram working, and immediately after programming the mcu with some questionable code, it no longer is able to be re-programmed. I get the error ST-LINK error (DEV_TARGET_NOT_HALTED)
Power-cycling the PCB, ST-Link and even the PC does not fix it.
I can tell the MCU is operating because it draws garbage on the LCD on powerup (problem I was working on before).
I believe the circuit is correct, because I've programmed this board dozens of times prior to this without issue.
The programming header on the board is routed to the MCU with no additional circuitry besides a 100nF cap on the NRST line. The BOOT0 pin is connected to gnd with a 1k resistor.
Has anyone else encountered this error and found a way to fix it?
