This is from a 2-channel RF Transmitter FlySky FS-GT2. I think the antenna's wire should be soldered onto this RF transmitter PCB, flat silver component, however, I do not know where to solder because of this unknown component.
\$\begingroup\$ Please clarify your specific problem or provide additional details to highlight exactly what you need. As it's currently written, it's hard to tell exactly what you're asking. \$\endgroup\$– Community BotOct 9, 2021 at 9:18
\$\begingroup\$ Check connectivity of the silver component to GND first. \$\endgroup\$– SyedOct 9, 2021 at 9:39
\$\begingroup\$ are you referring to the shielding can? \$\endgroup\$– KartmanOct 9, 2021 at 11:26
\$\begingroup\$ Yes, I am referring to the shielding can. Amy idea on removing it to what could be underneath \$\endgroup\$– Octane 663Oct 9, 2021 at 13:23
\$\begingroup\$ Removing that can would be challenging. I'd guess the antenna connection is that small dot in the center of the PCB tab protruding from the can (just above your arrow). Looks like there was an RF connector there that broke off. \$\endgroup\$– Mark LeavittOct 9, 2021 at 15:04
