I'm tying to drive a "Moisturizing Transducer Mist Maker Atomizer Film Plate" using a simple astable multivibrator circuit like this:
I can't make it work. No reaction from the atomizer. I checked and fine-tuned the frequency exactly:
Parameters of the atomizer:
Specifications:
Type: Atomizer Film Plate
Diameter:16mm
Color: white
Driving Voltage:DC 3-12V
Power:2.5W max.(Normal use 1.5W)
Resonant frequency: 108.0±5.0kHz
Resonant Impedance: 150Ωmax
Input voltage: 5~13V DC
Rated Voltage: 70Vp-p max
Service Life:>3000h
Atomization Amout: 50~100ml/hour
Cord length: 80mm
Why does frequency changes after connecting the atomizer? Without it I had 108 kHz, after connecting it risen to 120 kHz, so I had to add additional resistors to decrease it to 108 kHz again. What is causing this?
I also tried to connect it in series with transistor, hoping that series resonance will make it work.
No result with that, either. I also tried supply voltage of 9V, to no effect.
What am I missing here?
or maybe this:Input voltage: 5~13V DC
then, just to confuse things it says this:Rated Voltage: 70Vp-p max
so, given that I've pulled all that from your question, can you see how confusing the information you have provided is. Try and find a data sheet for the pizeo part. If you can't find one then you probably won't get anything other than bad guesses on this site. \$\endgroup\$
