I am using mini2440 board with external FPGA board, I am looking for one ARM+FPGA board with GPIO support.
As of now I am using mini2440 board with GPIO to control the hardware and sometimes using USB FPGA board to control the hardware. I am looking for the board with has ARM+FPGA support so that I can connect my hardware to the board to reduce the hardware.
Please let me know If you know any ARM+FPGA board in whcih i can port Linux and use it for industrial application.
Take a look at the Xilinx Zynq family (there is also a board available, the Zedboard), this is a FPGA with a hard Cortex-A9 core.
Since this is fairly new, please check if the software support is what you need.
  • \$\begingroup\$ @Tom, Thanks for the reference. I will definitely look into the board and let you know. Thank you for your time. \$\endgroup\$ – Suresh K Feb 25 '13 at 14:59
