8
I have a circuit made of a MOSFET that pulls the lower side of an inductor to ground while the other side is connected to a DC voltage source as follows:
Enter image description here
Then it is very simple to describe what's going to happen when the gate goes high.
According to U = L * dI/dt -> I = 1/L * Integral(U*dt) the current will start ramping up.
Next the gate is discharged. Since this forces the current to go to 0 A in a very small time span, the EMF created by it according to equation above will be a single high voltage rectangular pulse for the same time span. Since this is back-EMF it is also a negative voltage.
But this is not what happens in simulation or the real world. Instead the current is driven to the exact negative value that it had ramped up to before and flows through the body diode. So the magnetic flux not only went to zero, but it now reached a negative peak.
How can this be explained?
If the MOSFET forces the current to 0 A, what forces it to its negative peak?
So the inductor gets demagnetized which is pretty clear since the current is driven to zero. What's causing the consequent magnetization, the inductor can't magnetize itself!
I'm nearly done with my bachelor, but this I still can't get my head through :P
So this is the gate-source voltage driving the MOSFET and in blue the drain current through a 3 ohm resistor. This is the exact same setup as in simulation where the exact same thing happens:
(the current is just inverted)
Here is the LTspice file if interested: One Transistor forward _basic
Answer:
Thanks to @DKNguyen, the current can be mostly explained:
The current wave form is actually created by the parasitic drain-source capacitance (CDS) together with the body diode. When the MOSFET goes open, its CDS together with the inductor resonate in series while their peaks are decreasing:
When adding the body diode, the ringing is rectified and filtered giving the replica of the original current wave form:
Now the duty cycle can be adjusted to move them both together. I'm not sure why the slope equals the inductor slope though. There is more to this, but this answer seems satisfactory.
Big thanks to @DKNguyen and @devnull.
    \$\begingroup\$ there should only be one question ... this is a Q&A site, not a forum \$\endgroup\$
    – jsotola
    Oct 10, 2021 at 21:56
  • \$\begingroup\$ The MOSFET doesn't force the current to zero. It can't. That's the wrong idea that you need to break (and stomp on and destroy forever) in your mind. \$\endgroup\$
    – jonk
    Oct 10, 2021 at 22:03
  • \$\begingroup\$ @jsotola To me these seem like inherently the same question of what's going on when the Mosfet opens. \$\endgroup\$
    – menr1232
    Oct 10, 2021 at 22:15
  • \$\begingroup\$ replace the mosfet with a mechanical switch... place a diode in parallel with the switch \$\endgroup\$
    – jsotola
    Oct 10, 2021 at 22:39
  • \$\begingroup\$ @DKNguyen It should be assumed that there is a reverse diode parallel to the MOSFET. When the MOSFET tries to open, the current will reverse eventually. \$\endgroup\$
    – menr1232
    Oct 10, 2021 at 22:52
7
UPDATE:
I reran the simulation with a 10 µH inductor and got the following:
which seems indicative of behaviour similar to reverse recovery in a diode, maybe the body diode itself, but I don't think the conditions are correct for that. I think it's the MOSFET itself...though the same thing also appears with a BJT. That said, I'm a little suspicious that the slope matches the inductor charge slope, but I guess it's not surprising it matches since it is a current spike that must flow through the inductor regardless even if it is the transistor that is responsible.
100 ohms, 10 µH:
10 ohms, 10 µH:
It appears you were unlucky in that you chose a frequency and inductance too high so the current never had enough time to build up and stayed at a magnitude similar to the reverse recovery spike and everything bled together. Here is your simulation at 7 mH with a much lower frequency:
I did just simulate using switches instead of transistors and it does not exhibit an undershoot. The model for the switch assigned to the "SW" component was:
 .model MYSW SW(Ron=1 Roff=1Meg Vt=.5 Vh=-.4)
via the Spice directive, as per LTspice: Voltage Controlled Switches.
With 10 µH, adding 200 pF Cds and Cgs to the switch produces the following waveform which roughly resembles what you have so maybe it's not reverse recovery anything, but just parasitic capacitances, but it doesn't look like ringing as much as I thought it would:
NO LONGER RELEVANT:
An inductor has two modes: As a load, when a source is pumping current through it, it stores energy in its magnetic field. While this happens, the inductor voltage resists the source voltage. This is the back-EMF. In your posted circuit, that is when the switch is closed, the current flows clockwise and the inductor voltage is + on top, - on bottom.
The second mode is when the inductor is the source itself and this happens when the external source driving current through the inductor is decreased (or in extreme cases, removed/interrupted). When this happens, the inductor magnetic field collapses and the energy is released. The inductor uses this energy to try and maintain the current through itself (not the circuit) at the same level. Now, the inductor acts as a source. The inductor voltage is now - on top and + on the bottom. Just as if it were a battery. This is the forward-EMF. Current continues to flow clock wise.
The MOSFET tries to open, but the collapsing magnetic field in the inductor generates whatever voltage is necessary to punch through in order to keep current at the remaining level. There is only finite energy so it can’t keep this up forever and current decreases as energy runs out. But the higher the impedance present, the higher the voltage required, the more power is required, the faster the energy in the magnetic field is expended, and the faster the current falls to zero. The inductor forces the MOSFET to enter breakdown between source-drain in the above circuit to keep current flowing.
At no point does current reverse and flow counter clockwise. The inductor voltage is the only thing that reverses when the inductor goes from having it's magnetic field built up/charged to having its magnetic field collapse/expended, but the current continues clockwise the entire time.
Flyback diodes:
The MOSFET has a parasitic body diode, but it is not a flyback diode. In some circuits (like an H-bridge) it can serve the role of a flyback diode, but in your schematic it is not in the correct position to act as one. A true flyback diode gives the current through the inductor a lower impedance path to circulate in a loop through the inductor so that the voltage spike generated by the inductor is not as high and thus not as damaging. In your circuit, that would be a diode placed anti-parallel to the inductor. This works because the inductor only tries to maintain current flowing through itself, not the circuit loop. The current through the MOSFET can drop to zero near instantly, but as long as the current can find it's way around through the inductor, that's all it the inductor cares about.
Does that clear things up?
The current is much like a moving freight train. You can have the engine producing a force that pushes the train along. But throw up a wall to try and stop the train and that train will produce an enormous force via its momentum and inertia to smash through that wall to try and keep the train going at the same speed. It does this even if you cut the engine and it does this even if the force produce by the engine was not enough to push through the wall on its own (i.e. starting from zero speed and just accelerating up against the wall), similar to how the flyback voltage can be much higher than the source voltage.
  • \$\begingroup\$ The long comment chain has exceeded what is reasonable for comments. Therefore it has been moved to chat and should be continued there (link to the chatroom is below). --- As this bulk moving of comments to chat can only be done once per answer, any further comments posted here might be deleted without notice. From now onwards, keep it in chat, please! Any updates to the answer which are decided during the chat, can still be made via an edit to the answer., as usual. Thanks. \$\endgroup\$
    – SamGibson
    Oct 11, 2021 at 3:03
  • \$\begingroup\$ Comments are not for extended discussion; this conversation has been moved to chat. \$\endgroup\$
    – SamGibson
Inductors want to keep the current that is going through them constant at all cost (whether 0A, 100A etc.). When someone is trying to change the current, the inductor will inject a voltage to try and keep the current going. The faster you change the current, the higher the voltage spike becomes. If you have a free-wheeling diode, it does not take much voltage for the inductor to keep things going. The flux will die out slowly and current easily continues to go through the inductor, slowly dying out. Without this diode, the inductor is getting more and more desperate building up a higher and higher voltage. This is what an ignition coil does. The polarity depends on which direction current is getting changed. If the external factor is trying to increase the current, then the voltage getting induced by the coil is working against the power supply, trying to keep current the same. On the other hand if you are trying to decrease current (ex. turn off switch) then the inductor builds up a voltage to work with your power supply. I hope this makes sense. Btw. the capacitor does the opposite. It always wants to keep the voltage the same and will "inject" a current trying to keep it so.
  • \$\begingroup\$ If the inductor wants to keep the current going, why is it reversing the current on its own when the Mosfet turns off? \$\endgroup\$
    – menr1232
    Oct 10, 2021 at 22:11
    \$\begingroup\$ @menr1232 Is isn't reversing the current. \$\endgroup\$
    – DKNguyen
    Oct 10, 2021 at 22:38
Maybe this is not the solution to the problem, but it is worth noting that if we add a capacitor to the parasitic DS capacitance, the current doesn't change direction while Vgs is pulsing and the natural frequency changes considerably after:
