-2
it is possible to send more data through a given circuit using digital rather than analog transmission
Slide says the above thing but I am not really able to grasp this. How can we send more data in digital than analog. And what kind of circuit are we talking about here?
http://home.ubalt.edu/abento/650/physicaldlink/tsld005.htm here is the slide which says so. I don't think this is unreliable source tbh.
  • 5
    \$\begingroup\$ This statement is not really correct. Data are usually transmitted in Digital, although digital transmission can be modulated in the analog domain, wireless being a good example. \$\endgroup\$
    – Damien
    Oct 12 at 7:33
    \$\begingroup\$ Digital is just "analog with two states". So digital is a subset of analog. Using digital I cannot do everything I can do in analog. So digital is by definition more limited. So how can something that is more limited be more efficient? So the statement is very wrong. Where did you find this? \$\endgroup\$ Oct 12 at 7:36
    \$\begingroup\$ The key difference between analog and digital is that digital has a defined amount of noise immunity due to having a dead band between the logic-0 range and the logic-1 range, while analog tends to accumulate noise (uncorrelated noise always adds). Every practical digital circuit is really an analog circuit, there's no free lunch. \$\endgroup\$
    – MarkU
    Oct 12 at 7:46
  • \$\begingroup\$ That statement makes a number of assumptions about a) the required SNR of the link b) the redundancy in the source information c) the noise environment of the link, and probably a few others if I had more time to think. Only when you compare like with like given all the other constraints can you compare throughput of links. Sometimes analogue wins, sometimes digital. Wringing out redundancy offers huge gains, if the source material (like commercial audio and moving pictures) permits it. \$\endgroup\$
    – Neil_UK
    Oct 12 at 7:53
  • \$\begingroup\$ What is your application space? How far are you transmitting? Consider that the entire internet is a case of packets (i.e. digital data) being transferred between routers, so the short answer is that digital transmission is the dominant mode of transmission. "Better" assumes well-defined metric(s). Therefore, the question, as posed, is vague. \$\endgroup\$
    – Syed
    Oct 12 at 8:30
7
As a communications engineer (and someone dealing with a lot more digital signal processing than is good), this slides ... weak to wrong.
Advantages of Digital transmission
We have to be very clear here: when we say "data", we typically mean things that are already digital to begin with. Now, of course, some kind of digital data has an analog equivalent – for example, an MP3 file has the equivalent "analog sound". You could alternatively transmit that as an analogue signal. But how does an analog spreadsheet, or computer executable binary, look like? So, honestly, this slides premise is kind of from the 1960s...
So, all these comparisons only make sense for things that can be represented in both digital and analog signalling.
Since you say "circuit", I'm assuming you're referring to telephone; the third slide does seem to agree. Anyway, there's many other things, and this slideset very clearly ignores them without telling you.
third slide
So, for the rest of this, we talk about speech transported over 1970's telephone networks. None of this is relevant to any modern networks.
Not a good source, your slideset. Maybe learn from something else?
produces fewer errors than analog transmission.
Uff, that statement plainly makes no sense. In digital data, I can speak of "fewer errors", because errors are countable (as in: how many bits are wrong?). In analog, what's an error? When your voice sounds muffled, is that an error? When there's crackling, is that an error?
Because the transmitted data is binary (1s and 0s)
bing bing bing! Bullshit alarm!
This is wrong. What is transmitted takes one from a discrete set of waveforms. That might mean it's one of two frequencies (binary frequency shift keying), one of many frequency, one of two phases (binary phase shift keying) or one of many phases, or amplitudes, or combination of points in the amplitude/phase plane, or a multicarrier signal...
So, plain wrong.
it is easier to detect and correct errors
Now, this is correct: we have relatively good channel coding for digital data (there is analog channel coding too, but let's call it exotic).
is more efficient. It's possible to send more data through a given circuit using digital rather than analog transmission.
  1. what is "analog data"?!
  2. Big bit of truth here: There's no digital transmitted signals. Your transmission system might be digital, but what's going through the physical channel (i.e. the cable) is an analog thing.
The reason this is more efficient for voice is that we have excellent ways of encoding voice as digital signal, and it was hard back in the days to which the slide set allures to multiplex many analog voice channels onto one cable, so you could only have so many telephone calls on a single trunking line, but with digital audio/PCM you can interleave really easily. That makes it more efficient.
Anyway, these discussions are over: there's not been an analog telephone multiplex built in easily 30 years...
more secure, encryptable
yeah, analog cryptography so far isn't great.
  • \$\begingroup\$ Thanks sir. I was actually confused in lot of points as I didn't really find it easy to digest and believe, but I didn't dare to ask multiple questions and asked the question which confused me the most. Thanks for reading my mind and answering all questions. \$\endgroup\$
    – preeti
    Oct 12 at 10:08
  • \$\begingroup\$ No need to thank me! Instead, the usual way of expressing that an answer is good on this site is clicking the "upvote" triangle next to the answer. If the answer actually answers your question, you can accept it using the checkmark there, as well. \$\endgroup\$ Oct 12 at 19:02
The question and the slide deck are purple monkey dishwasher.
‘Digital’ transmission, if anything, is less efficient than analog in terms of spectrum usage for conveying an uncompressed baseband signal. Compare for example sending 3kHz audio vs. 64kbps digital for telephony, which requires at least 32KHz bandwidth. Clearly, the baseband audio is more efficient.
On the other hand, careful encoding of digital data into analog allows a modem to send data at 64kbps over that same 3kHz POTS line.
So, it’s a wash.
What’s going on? Every communications medium has an information carrying capacity determined by its bandwidth and its signal/noise ratio. This is called the Shannon Limit. The equation is as follows:
  • C = B * log2(1+ S/N)
where C is the achievable channel capacity, B is the bandwidth of the line, S is the average signal power and N is the average noise power.
More here: http://www.inf.fu-berlin.de/lehre/WS01/19548-U/shannon.html
So through the magic of adaptive DSP processing, the modem squeezes the maximum information throughput from that POTS line, getting pretty close to its Shannon limit.
Great, so we’re thinking about information and not getting stuck on the false analog vs. digital dichotomy posed by this naïve slide deck. Now what?
Working in digital allows us more degrees of freedom to analyze the information and remove redundancy prior to placing it on the line. This is the process of compression. Then whatever digital + analog method used to encode the information can use a lower symbol rate.
So we could take that 3kHz voice, digitize it, compress it using something like G.729, then re-encode with a modem and use perhaps 1/4 the bandwidth of the POTS line. Or, we could carry 4 audio streams on the same line.
Another more aggressive example is MPEG-2 video encoding which compresses video data about 200:1, allowing 1080i HD video (about 1Gbit/s) to be transmitted in the same bandwidth as a 6MHz legacy analog video channel.
Neither would be possible without some way of managing the entropy of the data stream through compression.
This is a very interesting question, and I particularly enjoyed reading the comments and see the difference between an academic's attempt to "simplify" a networking concept versus the accurate interpretation of the slide's words by practitioners.
So here is the situation - what the slide is trying to say, clearly not very successfully, is that when using digital transmission, in general, it is "easier" to send data due to noise tolerance. Because of that, all kinds of improvements can be made, hence making digital transmission more common than analog.
Specifically, if your line has 1V noise and your "1" is 3V and your "0" is 0V, you can send 8 bits and convey a number. Each bit will be "noisy", so if the first bit is 1, and the value is 2.6V, it is still a "1". So as long as your transition from 0 to 1 is "sharp", the transmitted result will be exactly what you sent. On the other hand, if you use the analog value to convey the same range of information, you are subject to the full noise in the line and you will never get the identical result.
Because of this simple fact, you can increase bandwidth but just flipping bits faster, as that is easier than cleaning the line. And you can do all kinds of other improvements to the transmission line, such as encryption, bit correction, etc.
But there are tons of exceptions and for every example, one can find a counter-example of a situation where the analog transmission would work better. And if you want to be strict, all transmission is analog, signals are continuous voltages. However, you have to draw the line at some level of abstraction so you let the lowest layer take care of how to reliably convey the "0" and "1", the deal with the rest of the transmission as digital, thus reaping the benefits.
