I received chips different from chips that I ordered. Already asked for refund.
But I am curious what these chips actually do. I searched several SMD code books, but had no luck. Does anybody have any clue what they could be?
It's SOT-23-6, Marking code 63M09. enter image description here
I have ordered battery ballancer ICs HY2213-BB3A.
But I do not think the chips I received are just some clones, because I measured no diode drop across pins 2-3 (there should be a diode internally). So I assume those are completely different chips.
  • \$\begingroup\$ electronics.stackexchange.com/a/334129/107479 \$\endgroup\$
    – dim
    Oct 13, 2021 at 10:55
  • \$\begingroup\$ Im not sure at all, but often on those packages there are Fets or Jfets \$\endgroup\$
    – user201301
    Oct 13, 2021 at 11:26
I probably found a good candidate.
I googled and found some strange page which is referring "63M09" and "OB2263MP". So it could be OB2263MP (Current Mode PWM Controller).
It's SOT-23-6, and I measured some diode drops and resistances across certain pins and measured values agree with internal schematic of this chip. So it is pretty much this chip. I am not 100% sure, I would have to test that chip in some circuit to be 100% sure.
    \$\begingroup\$ OB 2263 mp is correct part no. For 63mo9 I have used it in 12v 3amp power supply \$\endgroup\$ Jul 4, 2022 at 8:43
