At the beginning of the measuring task, I mixed up wires connecting my FTDI USB to UART cable (TTL-232R-3V3) with serial connector header pins (TX/RX/VCC/Gnd) on device (data modem). I didn't immediately noticed the error, just after ~4-5min, after discovered the smell of hot plastic. As a result, the FTDI cable connection header got very hot. How can I make sure that I haven't damaged the laptop's motherboard and the FTDI chip itself? I tried then connect with correct pins, it works and show output. Nevertheless, the cable header was extremely hot. Sure, this FTDI cable is not a MIL standard, what max temperature it can hold? Can I be sure that FTDI chip with its other components and laptop motherboard are fine?
Absolute maximum ratings for FT232R device are as follows:
extremely hot
means a different thing to different people ... you are basing your question on some unknown quantity \$\endgroup\$
