I want to understand the if else if priority and working for Verilog. In my code I can't seem to get to the 3rd condition and statement of the if else if construct. Why?
module alu #(parameter WIDTH=8) (in_a, in_b, opcode, alu_out, a_is_zero);
    input [2:0] opcode;
    input [WIDTH-1:0] in_a, in_b;
    output reg [WIDTH-1:0] alu_out;
    output reg a_is_zero;
    always @*
    begin
    a_is_zero=|in_a?0:1;
    if(opcode==000)begin
        alu_out=in_a;
        end else if (opcode==001) begin
            alu_out=in_a; end
             else if(opcode==010) begin
                alu_out= in_b+in_a; end
                else begin alu_out=in_a; end
    end
endmodule
failing to read the third condition-statement
You need to add a b base specifier to your 3-bit constants. In your code, 010 is the decimal value ten, not two. You declared opcode as a 3-bit signal, which means it can have decimal values in the range 0-7. Therefore, decimal 10 is not in the range, and if(opcode==010) will never be true. If a number is specified without a base, Verilog defaults to decimal format.
I added the 3'b prefix to your 3 constants below:
if(opcode==3'b000)begin
    alu_out=in_a;
    end else if (opcode==3'b001) begin
        alu_out=in_a; end
         else if(opcode==3'b010) begin
