I am using high voltage MOSFET in TO-220 package with a heatsink like this one:
heatsink
Under normal conditions, the temperature of heatsink does not exceed 90 degrees.
My MOSFET can run up to 120 degress according to the datasheet.
What kind of protection can I use so that the MOSFET temperature does not go above 120 degrees in an extraordinary situation? (For example, 150-200 degrees).
Could I connect a thermal fuse in series with the MOSFET? I suppose I'd have to attach the thermal fuse to the cooler.
Any ideas?
  • \$\begingroup\$ Any information on the attached circuit? If you have a reference and a spare comparator, using a thermistor may be the best option \$\endgroup\$ Oct 16, 2021 at 13:52
There are too many variables to calculate the temp based on on-state resistance, switching speed, air circulation, etc.
Directly measuring the case temperature will be your only option. Ideally, measure as close to the MOSFET tab as possible with a very small thermal fuse or, yes, mount on the back side of your heat sink.
Use heat-sink grease to thermally bond the MOSFET to your heat sink. If not a thermal fuse, you can use a thermal sensor and back off on the power via PWM in over temperature situations (the strategy really depends on your application.)
One-time use thermal fuses can be a pain when the trip. Polyfuses that reset are a bit more user friendly.
