-3
We would like to build a calculator using Arduino which uses 3 digit LCD and a keypad similar to digital phones. (# for plus , * for minus) Which components and way is good enough to not to run out of I/O ports?
  • \$\begingroup\$ With some care, you can share either the rows or columns between the display and the keyboard. \$\endgroup\$ – Chris Stratton Feb 26 '13 at 4:59
  • \$\begingroup\$ thank you very much for all answers and comments. It is my bad to not be able to check here again. We have designed the board from scratch , using the same model atmel processor on arduino uno. \$\endgroup\$ – kayhan yüksel May 23 '14 at 13:02
Check this arduinoo calculator kit: http://www.spikenzielabs.com/Downloadables/calc/CalcBuildInstructions.pdf Software and hardware is open source. They manages to connect 17 buttons and 6 digits LED. Wiring and sketch is very easy to understand
Not know which arduino you use, or the total number of pins you need, the basic answer is Shift Registers or (i2c/spi) Port Expanders. More specialized versions would be 7 segment led drivers (if you are using led 7 segment displays obviously), and keypad matrix ICs. If you are using actual lcd displays, it would highly depend on the display and/or controller for the display.
  • \$\begingroup\$ He is probably looking for shields. \$\endgroup\$ – Kortuk Feb 26 '13 at 4:20
