I want to collect pressure readings using 5 analog pressure sensors powered by a battery and collected with a DAQ. My sensors require 10 - 36 VDC and draw 38 mA max with 4 - 20 mA output. My battery source must have at least 5x the current draw if my research is correct. So 5 x 38 mA = 190 mA. I'm thinking a 24 VDC battery to power all five sensors. I'll wire them in parallel so voltage can be constant. The manufacturer states that the sensors have a loop resistance of 0 - 1000 ohms and an Rmax = 50(Vps - 10) ohms. I don't know what "loop resistance" is. Would the max R of each sensor be 50(24V - 10V)? Which of these do I use to find the Rtotal?
The DAQ I'm looking at has a 3.6 V battery, a load resistance of 12 ohms, and will read 4 - 20 mA coming from the sensors. How will the DAQ's load resistance impact the breadboard wiring? Does the sum of the sensor currents have to be less than the operating current of the DAQ? Will this setup work properly without frying my DAQ/Sensors?
https://www.dwyer-inst.com/Product/Pressure/SinglePressure/Transmitters/Series626-628#specs
https://www.dataloggerinc.com/product/vl-dcc-hr-current-data-logger/
