I've been staring at it for days and I still don't get how this is supposed to work. Capacitors aren't even connected to the negative rail, so how will they ever charge?
Blinking circuit
  • \$\begingroup\$ what is the voltage between the base and the emitter of each of the transistors? \$\endgroup\$
    – jsotola
    Oct 22, 2021 at 19:52
    \$\begingroup\$ This is a classic 'Astable Multivibrator'. No point in anybody here typing out how it works as that's been done a zillion times. Google that term, you'll find plenty of information. Good luck! Here's a video: youtube.com/watch?v=dQbrI_iQWig \$\endgroup\$
    – Kyle B
    Oct 22, 2021 at 19:57
    \$\begingroup\$ This has been written about so many times by so many people. But to understand it, you must be able to hold in your head dynamic situations. Not just static ones. Otherwise, this will elude you. There are videos and whole web pages on this. And to be honest, I have to say that those I've seen are different enough in approach that you could easily be confused. The reason for that is that different people have different ways of thinking about problems. Stuff that sings in one mind like a song may be a dull thud of nothing useful for someone else. So keep looking. \$\endgroup\$
    – jonk
    Oct 22, 2021 at 19:58
    \$\begingroup\$ Here's a long video that I've seen. There are things I do not like about it. But there are things I do like about it, too. You might start there. \$\endgroup\$
    – jonk
    Oct 22, 2021 at 20:02
  • \$\begingroup\$ Who says a capacitor has to be connected to the negative rail in order to be able to charge? \$\endgroup\$
    – Hearth
    Oct 23, 2021 at 0:15
5 Answers 5
It may be just slightly easier to see it drawn this way:
(I've left things to use \$V_{\!_\text{CC}}\$ rather than \$9\:\text{V}\$ to keep it more abstract for now, despite the specific resistor and capacitor values still present. I've kept all your part name-designations, though.)
Static Viewpoint
If you limit yourself to a static viewpoint, and if you assume that the BJTs have \$\beta \gt 100\$ and the LEDs each drop about \$2-3\:\text{V}\$ , then you'll find that both LEDs should be ON and that there should not be any oscillation.
Assuming saturation for the BJTs for a moment, we'd guess that:
$$I_{_\text{LED}}= \frac{V_{\!_\text{CC}}-V_{_\text{LED}}-V_{_\text{SAT}}}{R_1}$$
For the values given in your schematic, this will be \$I_{_\text{LED}}\le 15\:\text{mA}\$. Since \$R_3\$ can supply as much as \$\frac{9\:\text{V}-900\:\text{mV}}{47\:\text{k}\Omega}\approx 170\:\mu\text{A}\$ and assuming \$\beta\gt 100\$ then this is more than enough to supply and hold \$Q_1\$ into some degree of saturation.
That idea applies to both sides. So the circuit should be as I earlier wrote, that both LEDs should be ON and that there should not be any oscillation.
There are a few reasons why this isn't true:
  • The system can't instantly go from unpowered to stable state because of the capacitors. (It always takes some picoseconds for charges to arrange themselves.)
  • The parts are not identical and they never will be identical in any real construction. The only place they are identical is in a Spice program. And that's not real. This may cause a problem for a Spice program (perhaps solved by injecting noise.) But it doesn't cause any trouble for real circuits.
Finally, there will be a start-up transition period followed by two complementary (similar for each BJT, but not exactly similar) periods that form, together, the astable multivibrator behavior that is claimed for the circuit. To apprehend the circuit, you cannot mentally skim over the start-up transition period. So I'll focus on that in a moment.
Regardless, this is why I argue that you must be able to mentally hold dynamics in your mind while considering the circuit if you are to understand it. And this is where mental exercise helps a lot. The ability to do this does get much better with continual practice. (And it requires continual re-inforcement to remain proficient, as it may lapse a little with disuse.)
Start-up Transition
No parts are identical. Get that right.
And the capacitors are initially discharged.
(This isn't strictly true if you have a switch and turn the circuit on and off, repeatedly. You would need to wait for a little time after turning it off, before re-starting it if this assumption is to be strictly true.)
Depending on how fine-grained you want to be (in time), you could consider the very first atto-second, well before much can happen. The charges won't even have had time yet to re-arrange themselves. (Speed of light and all that.) If I discuss that process here, given past experience here I'm sure I'd need to defend what I write about the physics (which isn't electronics), so I'll just avoid those details I see and move on. It won't really help, anyway. Suffice it that there will be a very short period during which electron charges will very, very quickly place themselves on the surfaces of conductors and throughout the bulk semiconductor regions when you power this up and we can just assume all that has already happened and start from that point in time.
Once the physical re-arrangement of surface charges has happened, the first useful nano-second to examine will have the base of both BJTs pulled up to somewhere near \$900\:\text{mV}\$ and about \$170\:\mu\text{A}\$ in \$R_2\$ and \$R_3\$. This also means the collectors will be at the same voltage (almost, as the parts are different keep in mind) as their base voltages. The capacitors don't directly connect between the collector and the base of the same BJT. They cross-connect. So the collectors and bases won't be exactly the same. But likely very close. So they will be in active mode, at this first moment with their fuller \$\beta\$ value in play. This means both LEDs will (ignoring their capacitance as I'm assuming we have moved past that small detail) be ON.
So, expect a small flicker of sorts when this is first powered where both LEDs are very momentarily turned on.
However, one or another of the BJTs will be more ON and the other one slightly less so. The one that is more ON will be pulling harder on its collector and this fact will, because the capacitors at this moment still have \$0\:\text{V}\$ across them, hold the opposite BJT's base just that much closer to ground.
It doesn't have to be very much, because the collector current of an active-mode BJT goes by a factor of 10 for every \$60\:\text{mV}\$ difference across its base-emitter junction. So the BJT experiencing either a higher \$\beta\$ value and/or a lower base resistor value will win out over the opposing BJT.
In doing so, the opposing BJT will release its collector. (It does this very quickly because of the factor of 10 rule.) In releasing it, this allows the opposing BJT's LED and resistor to pull upward on the end of the capacitor that is already connected to the winning BJT's base, meaning still more base current supplied to the winning BJT and therefore an even better ability to crank the losing BJT's base down harder towards ground.
So. One of the two BJTs will rapidly win this battle and the starting condition will be that one of the BJTs will be ON and the other one *OFF. This whole process is pretty quickly decided.
The winning BJT's collector capacitor will have, by this time, been partially charged via the collector resistor and LED on one end and the opposing BJT's base resistor on the other end. But the capacitor polarity will be slightly more positive on the collector end than the base end because the collector resistor is so much smaller in value. So when the winning BJT wins more fully and hauls down still harder on its collector, this will also drive the losing BJT's base into negative voltage territory. It's hard to say by exactly how much. But somewhat. This clinches the fact that the losing BJT is fully OFF.
Now, keep in mind that we've only gone to the point of deciding that one BJT will win and the other will lose. However, this starting condition still has both capacitors as discharged. This is not a normal circumstance once the circuit goes into bistable oscillation. So we are still not yet out of the starting conditions and what we see here will never again occur. Not ever. This is a one-off. Keep that in mind.
Okay. With that held in mind, one BJT has won the battle. Let's call it \$Q_1\$. So \$Q_1\$'s collector is holding down one end of \$C_1\$, close to ground, with the other end holding \$Q_2\$'s base voltage also close to ground (or more likely slightly below ground.)
Meanwhile, \$C_2\$ has one end held close to about \$900\:\text{mV}\$ with the other end initially near that value, too, but now rapidly being pulled upwards by \$R_4\$ via \$D_2\$. So \$C_2\$ will be charging via a rate determined by \$\tau_{_{R4 C2}}=470\:\Omega\cdot 10\:\mu\text{F}=4.7\:\text{mS}\$. In a few milli-seconds, it will be charged up and during this short period \$Q_1\$ will be held in hard saturation and \$Q_2\$ will be held OFF.
Meanwhile, one end of \$C_1\$ is held close to ground by \$Q_1\$'s collector and the other end is being charged upwards via \$R_2\$. This has a rate determined by \$\tau_{_{R2 C1}}=47\:\text{k}\Omega\cdot 10\:\mu\text{F}=470\:\text{mS}\$. However, we only need to see a rise of perhaps \$900\:\text{mV}\$ (plus a little more to account for a slightly negative beginning) before this fact turns \$Q_2\$ ON, so we don't even need to wait one full period of \$470\:\text{mS}\$ but instead only a fraction of it.
The conclusion is that this very first, unique starting cycle will have both LEDs ON for a few milli-seconds, followed by just one of them ON for a period that is a third or less of an RC time constant (say \$100\:\text{ms}\$ in this case.)
This partial state will continue until \$Q_2\$ can turn ON enough to start hauling downward on its collector and thereby pull down on its collector-end of \$C_2\$, which by this time has accumulated almost \$8\:\text{V}\$ across it. So when \$Q_2\$ begins to haul down, the other end of \$C_2\$ will very very quickly cause \$Q_1\$'s base voltage to go well below ground and turn \$Q_1\$ completely OFF. \$Q_1\$ relaxes its grip on one end of \$C_1\$, which allows \$R_1\$ and \$D_1\$ to yank upwards and add still more current drive for \$Q_2\$ and now the bistable oscillation itself begins.
By this time, you should be able to work out more of the details of the bi-stable operation. Most of the hard work goes into understanding why it starts in the first place. The above, hopefully, adds a little light to that area.
(You should be able to work out the fact that once this circuit is up and running, it is driving the base voltages of each BJT well into negative voltage territory. With \$9\:\text{V}\$ as a source, perhaps down towards \$-7\:\text{V}\$ or so. This is likely to cause most BJTs to avalanche their base-emitter junctions. So these BJTs may work later as astable multivibrators for a while. But they won't be as good as before for analog work. Also, Spice will simulate the circuit as having some particular cycle time that does not take into account the avalanche behavior. In practice, the blinking period will be shorter than predicted because of it. Just FYI.)
Capacitors aren't even connected to negative rail, how will they ever charge?
They are. The negative terminal of each capacitor is connected to ground through the base-emitter junction of the transistors. The positive terminal is connected to +9 V via the LED and its current limiting resistor.
  • Due to imbalances in the component tolerances and the transistor switch-on one of the transistors will switch on before the other.
The rest of the operation you can read about in many online tutorials.
  • \$\begingroup\$ Yeah, I dunno if we can trust an answer about a transistor circuit from a guy named "Transistor"... ;) \$\endgroup\$
    – Kyle B
    \$\begingroup\$ @KyleB since Transistor gives an explanation and you don’t… plus 1. \$\endgroup\$
    – Solar Mike
    Oct 22, 2021 at 20:19
That circuit is a transistor astable multivibrator.
Start with Q2 having just been switched on with its base at 0.7V and its collector at 0V. Q1’s base will be at -8.3V and will be slowly rising as C2 charges through R3. Simultaneously the collector of Q1 will be rising as C1 charges via R1. The collector of Q1 will reach 9V before its base reaches 0.7V because C1 is charging through a resistance of 470R (R1) whereas C2 is charging through 47k (R3). A little while after the collector of Q1 reaches 9V, its base will reach 0.7V switching Q1 on and forcing its collector to 0V. Voltages across capacitors with a series resistance can’t change instantly and so as the left hand side of C1 drops to 0V, its right hand side must also drop by 9V taking the base of Q2 almost instantly down to -8.3V, switching Q2 off and enabling its collector to rise fairly quickly to 9V as C2 charges via R4. A little while later the base of Q2 reaches 0.7V because C1 has been charging via R2. Q2 switches on and its collector drops almost instantly to 0V taking the base of Q1 down to -8.3V. We are back where we started and the above described sequence repeats.
There is a design flaw in that circuit. The bases of the transistors are taken down to -8.3V and the typical maximum data sheet specified VBE for a small signal transistor is only -6V! There are a couple of ways around this, lower the supply voltage or add schottky diodes (low forward voltage drop) in series with the transistors’ bases.
This circuit is called an astable multivibrator.
The very short description is, once the circuit gets going, each capacitor charges through the transistor collector and discharges through the opposite transistor base. The two transistors take turns doing this as one triggers the other into its opposite state.
A more detailed breakdown of this circuit is here: https://www.electronics-tutorials.ws/waveforms/astable.html
Or, rather than diving down that rabbit hole, try a simulation and see the behavior for yourself, here.
A related circuit, the bistable multivibrator, is just this circuit with resistors instead of capacitors providing the feedback. It toggles only when triggered by an external signal.
  • \$\begingroup\$ Yes, that's right, but when the capacitors are charging through the collectors the charging current is also flowing through the 47k resistors. In fact the size of the 47k resistors determines the magnitude of the charging current. When the capacitors are discharging through the bases, the discharge current is also flowing through the 470R resistors and the size of those 470R resistors sets the magnitude of the discharge current. \$\endgroup\$
    – user173271
    Oct 22, 2021 at 22:40
  • \$\begingroup\$ I'm taking a different approach to explaining the circuit by using simulation to visualize it. \$\endgroup\$ Oct 23, 2021 at 0:02
That circuit has no input.
Who starts oscillations?
Oscillations are started by the electronic noise of the components, that are very small voltage or current sources that excite the circuit.
Resistors have thermal noise et cetera.
